Background...
Elevation 7.
64 devices, all Z-Wave. Mostly GE Enbrighten.
All linked to Home Control Assistant ("HCA") via Hubitat Maker API.
Struggled to include 2-Zooz Motion ZSE18 Sensors.
Both finally installed using the same procedure.
The first installed as Source=System.
The second installed as Source=User.
Installed community driver.
Problem...
Cannot get Maker API to recognize either of the Zooz Motion ZSE18 Sensors, i.e., they aren't listed with the previously installed 64 devices.
(Therefore, I cannot set up an interface with them from HCA.)
Yes, I clicked into the instance of Maker API in Apps.
However, like I said above, the two motion sensors "aren't listed". They don't even appear in the list of devices under "Allow Endpoint to Control These Devices". Therefore, I can't click on them.
This may sound silly, but you did change from Device to this driver and save? And did you hit "Configure" on the device settings page to bring the sensors attributes into the hub? Then set the parameters and save again?
What do the States on the top of the device's settings page show? Is the sensor working otherwise? (ignoring Maker for a minute)
Assuming that the driver name is 1) in parentheses below the given device label, and 2) is also set forth in the column titled "Type", then motion sensor [1]'s driver is "Zooz Motion Sensor ZSE18" and motion sensor [2]'s driver is "Zooz Motion Sensor ZSE18 Advanced".
I presume that "Zooz Motion Sensor ZSE18" is the generic driver as it only shows 9 State Variables and that "Zooz Motion Sensor ZSE18 Advanced" is the community driver that I downloaded from Hubitat and shows 12 State Variables.
[Your question "change from Device to this driver and save" is not clear.]
[There is no "Configure" button on the device detail page for Motion Sensor [1] (Zooz Motion Sensor ZSE18).
[Yes, I did hit the "Configure" button on the device detail page for Motion Sensor [2] (Zooz Motion Sensor ZSE18 Advanced).
[If by "parameters" you mean "Preferences" (as there is not section labeled parameters), then the answer is yes.]
Motion Sensor [1] shows:
Current States
acceleration : inactive
battery : 95
motion : inactive
State Variables (no values set)
configVal15 :
configVal14 :
configVal12 :
configVal19 :
configVal18 :
configVal17 :
lastBattery :
configVal32 :
configVal20 :
Motion Sensor [2] shows:
Current States
battery : 85
motion : inactive
powerSource : battery
State Variables
configVal15 : 0
isConfigured : true
configVal14 : 0
configVal12 : 8
configVal19 : 0
configVal18 : 30
configVal17 : 1
pendingRefresh : false
assocNodeIds : []
lastWakeUp : 1689664667428
configVal32 : 10
configVal20 : 1
Is the sensor working otherwise? (ignoring Maker for a minute).
[Yes. Both will show * motion : active when motion is detected.
Rebooted the Hub and the motion sensors finally showed up.
Not sure why rebooting was necessary, but I should have done it in the first place.
Thanks for the help.
