Maker API html push json attribute
What I'm trying to do: When a contact sensor reports the status "open", I'm doing a HTML push with rulemachine.
It then does a HTML push to my PRTG server to get an active alert in PRTG.
This works like a charm when I filter on the value (JSONPath): $.attributes[1].currentValue witch gives me the value "closed" or "open".
(example)
https://[HUB-IP]/apps/api/[APP-ID]/devices/[DEVICE-ID]/capabilities?access_token=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
    "capabilities": [
      "Configuration",
      "Refresh",
      "ContactSensor",
        "attributes": [
            "name": "contact",
            "currentValue": "closed",
            "dataType": "ENUM",
            "values": [
              "closed",
              "open"
      "Battery",
        "attributes": [
            "name": "battery",
            "currentValue": "99",
            "dataType": "NUMBER",
            "values": null
      "AccelerationSensor",
        "attributes": [
            "name": "acceleration",
            "currentValue": "inactive",
            "dataType": "ENUM",
            "values": [
              "inactive",
              "active"
      "ThreeAxis",
        "attributes": [
            "name": "threeAxis",
            "currentValue": null,
            "dataType": "VECTOR3",
            "values": null
      "TemperatureMeasurement",
        "attributes": [
            "name": "temperature",
            "currentValue": "22.88",
            "values": null
      "Sensor"
Now my problem: sometimes Maker API seems to do a switcheroo on the attribute sequence.
So $.attributes[1].currentValue now does not give me the contact sensor's open/closed value, but it gives me the battery value.
I then have to manualy request maker api what the new sequence of attributes is.
(example)
    "capabilities": [
      "Configuration",
      "Refresh",
      "Battery",
        "attributes": [
            "name": "battery",
            "values": null
      "ContactSensor",
        "attributes": [
            "name": "contact",
            "dataType": "ENUM",
            "values": [
              "closed",
              "open"
        "attributes": [
            "dataType": "ENUM",
            "values": [
              "inactive",
              "active"
      "ThreeAxis",
        "attributes": [
            "values": null
        "attributes": [
            "values": null
      "Sensor"
So in the example the attribute number for open/closed is now: $.attributes[2].currentValue
Is there a way around this, or is there a way Maker API always respects the same sequence of attributes?
Maybe try (untested by me):
$.attributes[?(@.name == 'contact')].currentValue
so that you're not relying on key order?
That did the trick, thx!
