Maker API - example responses for lots of various device types
Thanks for working on this. I'll post my device data:
[{"name":" Door Aq Bsmt ->tradfri plug","label":"Door Aq ED44","type":"XiaomiDoor/WindowSensor w/Route","id":"310","date":"2020-04-27T16:45:05+0000","model":null,"manufacturer":null,"capabilities":["TemperatureMeasurement","Battery","ContactSensor","Sensor"],"attributes":{"battery":"100","dataType":"NUMBER","values":null,"batteryLastReplaced":"Tue Nov 20 22:13:17 EST 2018","contact":"closed","lastCheckin":"1588005905584","lastClosed":"1554091588306","lastOpened":"1554091585158","temperature":"20"},"commands":[{"command":"resetBatteryReplacedDate"},{"command":"resetToClosed"},{"command":"resetToOpen"}]},{"name":"Motion Hue Frt Door","label":"Motion Front Door Hue ","type":"Hue Motion Sensor","id":"712","date":"2020-05-28T14:31:47+0000","model":null,"manufacturer":null,"capabilities":["IlluminanceMeasurement","TemperatureMeasurement","Battery","MotionSensor","Configuration","Refresh","Sensor"],"attributes":{"battery":"64","dataType":"NUMBER","values":null,"illuminance":"67","motion":"inactive","temperature":"71.82"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Addition Lamp A8B0","label":"Addition Lamp ","type":"Generic Zigbee Bulb","id":"746","date":"2020-05-28T04:45:49+0000","model":null,"manufacturer":null,"capabilities":["Switch","Configuration","SwitchLevel","Refresh","Actuator","Light","ChangeLevel"],"attributes":{"level":"60","dataType":"ENUM","values":["on","off"],"switch":"off"},"commands":[{"command":"configure"},{"command":"off"},{"command":"off"},{"command":"on"},{"command":"on"},{"command":"refresh"},{"command":"setLevel"},{"command":"startLevelChange"},{"command":"stopLevelChange"}]},{"name":"Door Kitchen Sylvania","label":"Door Kitchen","type":"Generic Zigbee Contact Sensor","id":"821","date":"2020-05-28T14:20:10+0000","model":null,"manufacturer":null,"capabilities":["TemperatureMeasurement","Battery","ContactSensor","Configuration","Refresh","Sensor"],"attributes":{"battery":"75","dataType":"NUMBER","values":null,"contact":"closed","temperature":"73.60"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Contact Sensor","label":"Door Garage 1","type":"Generic Zigbee Contact Sensor","id":"825","date":"2020-05-28T13:16:05+0000","model":null,"manufacturer":null,"capabilities":["TemperatureMeasurement","Battery","ContactSensor","Configuration","Refresh","Sensor"],"attributes":{"battery":"55","dataType":"NUMBER","values":null,"contact":"closed","temperature":"66.20"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Contact Sensor","label":"Door Side Adtn","type":"Generic Zigbee Contact Sensor","id":"826","date":"2020-05-28T13:50:59+0000","model":null,"manufacturer":null,"capabilities":["TemperatureMeasurement","Battery","ContactSensor","Configuration","Refresh","Sensor"],"attributes":{"battery":"24","dataType":"NUMBER","values":null,"contact":"closed","temperature":"71.60"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Contact Sensor","label":"Door Driveway","type":"Generic Zigbee Contact Sensor","id":"827","date":"2019-11-18T15:34:53+0000","model":null,"manufacturer":null,"capabilities":["TemperatureMeasurement","Battery","ContactSensor","Configuration","Refresh","Sensor"],"attributes":{"battery":"100","dataType":"NUMBER","values":null,"contact":"closed","temperature":"44.60"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Door Slider Multi AAA","label":"Door Slider.","type":"SmartSense Multi Sensor V4","id":"829","date":"2020-05-28T14:27:27+0000","model":null,"manufacturer":null,"capabilities":["TemperatureMeasurement","Battery","ContactSensor","Configuration","ThreeAxis","AccelerationSensor","Refresh","Sensor"],"attributes":{"acceleration":"inactive","dataType":"VECTOR3","values":null,"battery":"100","contact":"closed","temperature":"69.77","threeAxis":"[x:-110,y:999,z:-20]"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Contact Sensor","label":"Door Rear Old","type":"Generic Zigbee Contact Sensor","id":"832","date":"2020-05-28T14:20:33+0000","model":null,"manufacturer":null,"capabilities":["TemperatureMeasurement","Battery","ContactSensor","Configuration","Refresh","Sensor"],"attributes":{"battery":"49","dataType":"NUMBER","values":null,"contact":"closed","temperature":"75.20"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Contact Sensor","label":"Door Front","type":"Generic Zigbee Contact Sensor","id":"833","date":"2020-05-28T14:21:23+0000","model":null,"manufacturer":null,"capabilities":["TemperatureMeasurement","Battery","ContactSensor","Configuration","Refresh","Sensor"],"attributes":{"battery":"62","dataType":"NUMBER","values":null,"contact":"closed","temperature":"73.40"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Generic Zigbee Contact Sensor","label":"Door Garage 2","type":"Generic Zigbee Contact Sensor","id":"940","date":"2020-05-28T13:32:38+0000","model":null,"manufacturer":null,"capabilities":["TemperatureMeasurement","Battery","ContactSensor","Configuration","Refresh","Sensor"],"attributes":{"battery":"62","dataType":"NUMBER","values":null,"contact":"closed","temperature":"68.00"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Siren Dome","label":"Siren Dome","type":"Dome Siren","id":"1004","date":"2020-05-28T04:00:18+0000","model":null,"manufacturer":null,"capabilities":["Switch","Battery","Alarm","Configuration","Tone","Refresh","Actuator","SpeechSynthesis","Chime"],"attributes":{"alarm":"off","dataType":"ENUM","values":["on","off"],"battery":"100","soundEffects":"{1=Chime2, 2=Melody1, 3=Chime3, 4=Chime1, 5=Melody2, 6=Melody3, 7=Alarm1, 8=Alarm2, 9=Tone2, 10=Tone1}","soundName":null,"status":"off","switch":"off"},"commands":[{"command":"beep"},{"command":"both"},{"command":"configure"},{"command":"off"},{"command":"off"},{"command":"on"},{"command":"playSound"},{"command":"refresh"},{"command":"siren"},{"command":"speak"},{"command":"stop"},{"command":"strobe"},{"command":"testAlarm1"},{"command":"testAlarm2"},{"command":"testChime1"},{"command":"testChime2"},{"command":"testChime3"},{"command":"testMelody1"},{"command":"testMelody2"},{"command":"testMelody3"},{"command":"testTone1"},{"command":"testTone2"}]},{"name":"Basement Switch Aeon","label":"Basement Switch Aeon Micro","type":"Aeon Micro Switch","id":"1015","date":"2020-05-24T03:04:20+0000","model":null,"manufacturer":null,"capabilities":["Switch","Configuration","Refresh","Actuator"],"attributes":{"switch":"off","dataType":"ENUM","values":["on","off"]},"commands":[{"command":"configure"},{"command":"flash"},{"command":"off"},{"command":"on"},{"command":"refresh"},{"command":"strobe"}]},{"name":"Motion Kitchen","label":"Motion Kitchen AQ Sensor","type":"Zigbee - Xiaomi/Aqara Motion Sensor-Markus","id":"1128","date":"2020-05-28T14:21:10+0000","model":null,"manufacturer":null,"capabilities":["IlluminanceMeasurement","Battery","MotionSensor","PresenceSensor","Sensor","Initialize"],"attributes":{"battery":"100","dataType":"ENUM","values":["present","not present"],"batteryLastReplaced":"Fri Jan 25 17:52:54 EST 2019","driver":"v0.6.1.0521","illuminance":"46","lastCheckin":"2020-05-28 10:20:09","lastCheckinEpoch":"1590675609288","motion":"inactive","presence":"present"},"commands":[{"command":"initialize"},{"command":"resetBatteryReplacedDate"}]},{"name":"Linear/Vision Siren","label":"Siren Utilitech","type":"Linear/Vision Siren","id":"1450","date":"2020-05-27T04:00:32+0000","model":null,"manufacturer":null,"capabilities":["Switch","Battery","Alarm","Configuration","Refresh","Actuator"],"attributes":{"alarm":"off","dataType":"ENUM","values":["on","off"],"battery":"80","switch":"off"},"commands":[{"command":"both"},{"command":"configure"},{"command":"off"},{"command":"off"},{"command":"on"},{"command":"refresh"},{"command":"siren"},{"command":"strobe"}]},{"name":"Aeon Siren","label":"Siren Aeon","type":"Aeon Siren","id":"1800","date":"2020-03-29T01:50:25+0000","model":null,"manufacturer":null,"capabilities":["Switch","Alarm","Configuration","Tone","Refresh","Actuator","AudioVolume"],"attributes":{"alarm":"off","dataType":"NUMBER","values":null,"mute":"unmuted","switch":"off","volume":"2"},"commands":[{"command":"beep"},{"command":"both"},{"command":"configure"},{"command":"mute"},{"command":"off"},{"command":"off"},{"command":"on"},{"command":"refresh"},{"command":"setVolume"},{"command":"siren"},{"command":"strobe"},{"command":"unmute"},{"command":"volumeDown"},{"command":"volumeUp"}]},{"name":"Motion Front Iris","label":"Motion Front Door Stairs","type":"Generic Zigbee Motion Sensor","id":"1929","date":"2020-05-28T14:21:48+0000","model":null,"manufacturer":null,"capabilities":["TemperatureMeasurement","Battery","MotionSensor","Configuration","Refresh","Sensor"],"attributes":{"battery":"100","dataType":"NUMBER","values":null,"motion":"inactive","temperature":"67.03"},"commands":[{"command":"configure"},{"command":"refresh"}]},{"name":"Aeotec Siren 6","label":"Siren 6 Aeotec","type":"Aeotec Siren 6","id":"2121","date":"2020-03-20T20:31:50+0000","model":null,"manufacturer":null,"capabilities":["Switch","Alarm","Configuration","Refresh","Actuator","AudioVolume"],"attributes":{"alarm":"off","dataType":"NUMBER","values":null,"mute":"muted","switch":"off","volume":"100"},"commands":[{"command":"both"},{"command":"configure"},{"command":"mute"},{"command":"off"},{"command":"off"},{"command":"on"},{"command":"refresh"},{"command":"setVolume"},{"command":"siren"},{"command":"strobe"},{"command":"unmute"},{"command":"volumeDown"},{"command":"volumeUp"}]},{"name":"Aeotec Siren 6 Component Chime","label":"Aeotec Siren 6 - Chime","type":"Aeotec Siren 6 Component Chime","id":"2122","date":"2020-04-25T14:55:38+0000","model":null,"manufacturer":null,"capabilities":["Switch","Tone","Actuator","AudioVolume","Chime"],"attributes":{"mute":"unmuted","dataType":"NUMBER","values":null,"soundEffects":"{1=Ding Dong, 2=Ding Dong Tubular Bell, 3=Traditional Buzzer, 4=Electric Buzzer, 5=Westminster Chimes, 6=Chimes, 7=Cuckoo, 8=Traditional Bell, 9=Smoke Alarm (Low), 10=Smoke Alarm (High), 11=Fire Evacuation Buzzer, 12=Carbon Monoxide Sensor, 13=Klaxon, 14=Klaxon (Deep), 15=Warning Tone, 16=Tornado Siren, 17=Alarm, 18=Deep Alarm Tone, 19=Alarm (Archangel tone), 20=Alarm (Shrill), 21=Digital Siren, 22=Alert Series, 23=Bell, 24=Clock Buzzer, 25=Christmas Tree, 26=Gong, 27=Single Bell Ting, 28=Tonal Pulse, 29=Upwards Tone, 30=Door Open}","soundName":"27. Single Bell Ting","status":"stopped","switch":"off","volume":"25"},"commands":[{"command":"beep"},{"command":"mute"},{"command":"off"},{"command":"on"},{"command":"playSound"},{"command":"setVolume"},{"command":"stop"},{"command":"unmute"},{"command":"volumeDown"},{"command":"volumeUp"}]},{"name":"Zooz Siren zse19","label":"Siren Zooz ZSE19","type":"Zooz S2 Multisiren","id":"2378","date":"2020-05-28T14:17:46+0000","model":null,"manufacturer":null,"capabilities":["TemperatureMeasurement","RelativeHumidityMeasurement","Switch","Battery","Alarm","Configuration","Tone","Refresh","Sensor","Actuator","AudioVolume","Chime"],"attributes":{"alarm":"off","dataType":"NUMBER","values":null,"battery":"100","humidity":"75.3","mute":"unmuted","soundEffects":null,"soundName":null,"status":"stopped","switch":"off","temperature":"69.3","volume":"100"},"commands":[{"command":"beep"},{"command":"both"},{"command":"configure"},{"command":"mute"},{"command":"off"},{"command":"off"},{"command":"on"},{"command":"playSound"},{"command":"refresh"},{"command":"setVolume"},{"command":"siren"},{"command":"stop"},{"command":"strobe"},{"command":"unmute"},{"command":"volumeDown"},{"command":"volumeUp"}]},{"name":"Inovelli Mega Switch","label":"Light Addition Switch 1","type":"Inovelli Dimmer Red Series LZW31-SN","id":"3466","date":"2020-05-28T02:41:26+0000","model":null,"manufacturer":null,"capabilities":["Switch","Polling","Configuration","SwitchLevel","Refresh","EnergyMeter","PowerMeter","Sensor","Actuator","HoldableButton","PushableButton"],"attributes":{"energy":"16.090","dataType":"ENUM","values":["on","off"],"firmware":"1.35","held":"1","lastActivity":"2020 May 27 Wed 10:41:26 PM","lastEvent":" Tap \u25b2","level":"90","numberOfButtons":"8","power":"0","pushed":"1","switch":"off"},"commands":[{"command":"childOff"},{"command":"childOn"},{"command":"childRefresh"},{"command":"childSetLevel"},{"command":"configure"},{"command":"holdDown"},{"command":"holdUp"},{"command":"off"},{"command":"on"},{"command":"poll"},{"command":"pressDownX1"},{"command":"pressDownX2"},{"command":"pressDownX3"},{"command":"pressDownX4"},{"command":"pressDownX5"},{"command":"pressUpX1"},{"command":"pressUpX2"},{"command":"pressUpX3"},{"command":"pressUpX4"},{"command":"pressUpX5"},{"command":"refresh"},{"command":"reset"},{"command":"setAssociationGroup"},{"command":"setLevel"}]},{"name":"Keypad IL02 Front Door","label":"Keypad IL02 Front Door","type":"Centralitex Keypad","id":"3658","date":"2020-05-28T13:35:16+0000","model":null,"manufacturer":null,"capabilities":["TemperatureMeasurement","Battery","ContactSensor","MotionSensor","Alarm","Configuration","Tone","Refresh","LockCodes","Sensor","TamperAlert","PushableButton","SecurityKeypad"],"attributes":{"alarm":"off","dataType":"NUMBER","values":null,"armMode":"disarmed","battery":"57","codeChanged":"deleted","codeLength":null,"contact":null,"lastUpdate":"Sun, May 24 2020 @ 6:27:32.061 PM EDT","lockCodes":"{}","maxCodes":null,"motion":"inactive","numberOfButtons":null,"pinStatus":"Accepted","pushed":null,"securityKeypad":"disarmed","tamper":"clear","temperature":"73"},"commands":[{"command":"acknowledgeArmRequest"},{"command":"armAway"},{"command":"armCode"},{"command":"armHome"},{"command":"armNight"},{"command":"beep"},{"command":"both"},{"command":"configure"},{"command":"deleteCode"},{"command":"deleteCode"},{"command":"disarm"},{"command":"entry"},{"command":"getCodes"},{"command":"getCodes"},{"command":"off"},{"command":"panicContact"},{"command":"pinStatusSet"},{"command":"refresh"},{"command":"sendInvalidKeycodeResponse"},{"command":"setArmedAway"},{"command":"setArmedNight"},{"command":"setArmedStay"},{"command":"setCode"},{"command":"setCode"},{"command":"setCodeLength"},{"command":"setCodeLength"},{"command":"setDisarmed"},{"command":"setEntryDelay"},{"command":"setExitAway"},{"command":"setExitDelay"},{"command":"setExitNight"},{"command":"setExitStay"},{"command":"siren"},{"command":"ssekey"},{"command":"strobe"},{"command":"testCmd"},{"command":"version"}]},{"name":"Zooz Double Plug Outlet Advanced","label":"Candles living room","type":"Zooz Double Plug Outlet Advanced","id":"4875","date":"2020-05-28T14:34:17+0000","model":null,"manufacturer":null,"capabilities":["Switch","Refresh","EnergyMeter","PowerMeter","Sensor","Actuator","VoltageMeasurement","Outlet"],"attributes":{"current":"0","dataType":"NUMBER","values":null,"currentHigh":"0.13","currentLow":"0","energy":"0.68","energyDuration":"69.7 Days","energyTime":"1584654482111","power":"0","powerHigh":"3.7","powerLow":"0","switch":"off","voltage":"0","voltageHigh":"130","voltageLow":"0"},"commands":[{"command":"off"},{"command":"off"},{"command":"on"},{"command":"on"},{"command":"refresh"},{"command":"reset"}]},{"name":"Lightify outlet","label":"Candle Kitchen","type":"Generic Zigbee Outlet","id":"5002","date":"2020-05-27T03:30:00+0000","model":null,"manufacturer":null,"capabilities":["Switch","Configuration","PowerMeter","Sensor","Actuator","Outlet"],"attributes":{"power":"0","dataType":"ENUM","values":["on","off"],"switch":"off"},"commands":[{"command":"configure"},{"command":"off"},{"command":"off"},{"command":"on"},{"command":"on"},{"command":"refresh"}]},{"name":"Zooz Central Scene Dimmer","label":"Light Kitchen","type":"Zooz Central Scene Dimmer","id":"5197","date":"2020-05-28T13:32:26+0000","model":null,"manufacturer":null,"capabilities":["Switch","Configuration","SwitchLevel","Refresh","Actuator","HoldableButton","Light","PushableButton","DoubleTapableButton","ReleasableButton","ChangeLevel"],"attributes":{"doubleTapped":"2","dataType":"ENUM","values":["on","off"],"held":null,"level":"99","numberOfButtons":"2","pushed":"2","released":null,"switch":"off"},"commands":[{"command":"configure"},{"command":"doubleTap"},{"command":"hold"},{"command":"off"},{"command":"off"},{"command":"on"},{"command":"on"},{"command":"push"},{"command":"refresh"},{"command":"release"},{"command":"setLevel"},{"command":"startLevelChange"},{"command":"stopLevelChange"}]},{"name":"Generic Zigbee Bulb","label":"Light Pantry Counter","type":"Generic Zigbee CT Bulb (dev)","id":"5518","date":"2020-05-26T01:49:01+0000","model":null,"manufacturer":null,"capabilities":["Switch","Configuration","SwitchLevel","Refresh","Actuator","ColorTemperature","Light","ChangeLevel"],"attributes":{"colorName":"Incandescent","dataType":"ENUM","values":["on","off"],"colorTemperature":"2702","level":"2","switch":"off"},"commands":[{"command":"configure"},{"command":"off"},{"command":"off"},{"command":"on"},{"command":"on"},{"command":"refresh"},{"command":"setColorTemperature"},{"command":"setLevel"},{"command":"startLevelChange"},{"command":"stopLevelChange"}]},{"name":"Device","label":"Siren Zooz Red","type":"Dome Siren","id":"5520","date":"2020-05-18T01:23:06+0000","model":null,"manufacturer":null,"capabilities":["Switch","Battery","Alarm","Configuration","Tone","Refresh","Actuator","SpeechSynthesis","Chime"],"attributes":{"alarm":"off","dataType":"ENUM","values":["on","off"],"battery":null,"soundEffects":"{1=Chime2, 2=Melody1, 3=Chime3, 4=Chime1, 5=Melody2, 6=Melody3, 7=Alarm1, 8=Alarm2, 9=Tone2, 10=Tone1}","soundName":null,"status":"off","switch":"off"},"commands":[{"command":"beep"},{"command":"both"},{"command":"configure"},{"command":"off"},{"command":"off"},{"command":"on"},{"command":"playSound"},{"command":"refresh"},{"command":"siren"},{"command":"speak"},{"command":"stop"},{"command":"strobe"},{"command":"testAlarm1"},{"command":"testAlarm2"},{"command":"testChime1"},{"command":"testChime2"},{"command":"testChime3"},{"command":"testMelody1"},{"command":"testMelody2"},{"command":"testMelody3"},{"command":"testTone1"},{"command":"testTone2"}]}]
