Maker API CloudURL not working? Or am I doing something wrong?
I am trying both local and cloud end-point urls to send a simple On command to a kasa plug. Both Url's kickback an error.
{"error":true,"type":"AppException","message":"Not Found"}
http://192.168.1.XXX/apps/api/673/devices/47/on/?access_token=XXXXXXX-XXXXX-XXXX
https://cloud.hubitat.com/api/074a5084-05a5-4146-8701-23e69bc1ae62/apps/673/devices/47/on/?access_token=XXXXXXX-XXXXX-XXXX
Is that series of numbers after "api/" the token-id? It's different from the token that was generated.
I've removed the maker api program, re-installed, rebooted the hub. Both links do not work.
Also, Get all devices and full details for cloud kicks back:
No response from Hub
Is there anything I can do to troubleshoot why the cloud endpoint url isn't reachable? Should I uninstall the app, and then reboot and reinstall?
Yes, before and after removing and reinstalling the Maker API app. I am going to try to uninstall, reboot, reinstall, select all apps and then generate the token. This was working fine weeks ago. I just came back to tinker with it for an idea I had and seeing that it's no longer working for me.
EDIT: That fixed it. Reboot after removal of app, did the trick. Working as expected now.
