I'm trying to use a Kindle dashboard app that needs Maker API.
I'm able to load a Hubitat dashboard from the local LAN with no security, and the app promises to grab the access token if there's no login, so it should work, right? Nope.
I'm happy to enter the access token manually if I knew where to find it. Could someone tell me which questions I should ask?
Did you install the MakerAPI app?
Thanks for responding.
Yes, there's a Maker API in my Apps list. It's there I find Settings including Allow Access by Local IP, and that's enabled, Remote/Cloud is not.
If. you go to the bottom of the MakerAPI app page there are some “sample” URLs copy the string after access_token=
Note: You will need to authorize all devices that you want to make accessible here also.
Got it working after uninstall/reinstall both Maker API and Kindle app. Awesome.
By Authorize I believe you mean select and save the device list under Maker API settings. It's working now! Thanks.
