Main page gone
Got the new Hubitat. Connected and played around a bit. Cant seem to get back to the main page where I can add devices and apps. How do I get back there?
Thx
Try http://findmyhub.hubitat.com. If you don't have a static or reserved I address for it and that's what you were using, it's possible it will change from time to time. Another option that might work is http://hubitat.local.
I may need to clearify. Im on the Hubitat. Im on the first Dashboard I created. I want to go back to the main page to registre and add some apps and devices - but cant seem to find that page again.
The above actually does sound like that, in general. But if you want to add devices to this dashboard specifically and they aren't showing up, make sure they are authorized first in Apps > Hubitat Dashboard > (your dashboard). This is from the interface accessible via the above. Once you do that, you should see them as devices you can use on that Dashboard.
If it's something else, maybe a screenshot would help explain?
I would love to attach a screenshot, but whenever I try, the page says “ Sorry, you can't embed media items in a post.”….
Go here and join the "Owners" group and it should let you:
https://community.hubitat.com/g
(it may also now already, but the above is good either way!)
Ok. So I played around a bit, made a Dash and than wanted to return to the main page to registrer and add some devices. Just cant find that main page again… Basicly stuck here.
That looks like the mobile app. You can use that to get to the admin interface (under Tools), but there's no need. I'd try one of my suggestions from above, which you can do in any browser--and then you don't get the extra app UI around everything too, which you don't need.
I will give it a go and if not sucessfull, I will try on a pc. Thanks for your help :slight_smile:
As @bertabcd1234 has alluded to, it appears that you were using a Web browser then you left the Browser and opened the Hubitat App to test your new dashboard.
To get back into a Browser, you need to leave the App.
