I would like to be notified when the mail carrier has delivered mail.
I have a traditional freestanding metal mailbox in the corner of my front yard, next to the sidewalk.
I want my automation to be discrete. I don’t want the mail carrier to see some contraption and think maybe it’s some kind of booby trap.
First, I added a Samsung SmartThings multi sensor to the bottom of the mailbox to detect vibration when the mail carrier opened up the box. However, the vibration sensor is so sensitive that it picks up cars driving by, and even, sometimes, airplanes flying overhead. There is no way to adjust the sensitivity that I’m aware of.
So I placed a small motion sensor (Iris v2) on the bottom of the mailbox. After some experimentation, I placed the motion sensor pointing down towards the ground. Despite it pointing down, it detects the motion of the mail carrier. It’s pointing down so that it does not pick up passing cars. I would never have guessed that pointing it down would work as well as it does.
However, it also picks up anyone walking by on the sidewalk, and not just the mail carrier. So now I’m planning to use the vibration sensor in conjunction with the motion sensor. My rule will be if motion AND vibration are detected, then I have mail delivery.
Now, if a car drives by at the same time as someone is walking by the mailbox, I will get a false positive.
Is there any vibration sensor whose sensitivity's can be adjusted? That would be a huge help. My vibration sensor is way too sensitive.
By the way, I’m aware that my sensors are not designed for outdoors. However, they are under the mailbox. They may get wet if there is a driving rain. However, I live in the desert, so I don’t get a lot of rain. I consider my setup to be an experiment. Maybe the sensors will hold up outside or maybe not.
Also, I did try using a contact sensor on the mailbox door, but as I said I wanted something discrete, and I wasn’t able to achieve that with the contact sensor.
) and that is one reason why I’m going with sensors on the bottom outside.
