So here is an interesting one..
I have a global variable set up that uses a rule which reports the last state of certain Lutron dimmers using the %text% feature. The idea is because Lutron reports the difference between a digital and physical interaction, I can parse that word to decide whether I should execute certain fades. I noticed some of that logic has gone wonky in 2.3.5
I can see in the event log for certain Lutron dimmers digital interactions are now showing up as physical, but that are set by the hub and should clearly be digital. Problem is that it is sporadic, but it only seems to apply to certain dimmers as far as I can see. A scene can be activated via a mode change, and the interaction logged as physical when it should be logged as digital. I can turn off the scene manually and then enable it again to display the correct digital interaction, but not every time.
I thought maybe I should reboot Lutron Hub and Hubitat, but no go there. I have rolled back to 2.3.4.153 to see if maybe it's been weird longer than I have known about, but I noticed it was wonky pretty quick while cooking and having the lights fade on me in the kitchen.
Any ideas would be appreciated.
