I received my Lutron Smart Bridge Pro a last week and finally had some time to set it up today. Setup was easy enough and I was able to add a 5 button Pico without too much difficult though it did take reading through a number of posts before it all made sense.
Next, I added a Button Controller, named it, selected my 5 button Pico and started adding the buttons and associated actions. Iβm running into a number of odd, likely user related issues when adding buttons and actions. All 5 buttons are being used to control a GE Z-Wave in-wall dimmer and Iβd like the buttons to do the following:
B1: On 100% Brightness
B2: Increase brightness while button is being held, stop when released
B3: Set brightness to 20%
B4: Decrease brightness while button is being held, stop when released
B5: Off
I'm using the Lutron Pico device type. I tried Fast Pico and could get that working either.
Here's how my Button Controller is setup:
Button 1, 3, and 5 work mostly as expected. Button 5 gently ramps down from the current brightness to 0. Buttons 3 and 5 don't ramp at all--they go to their set levels abruptly with no ramping.
Buttons 2 and 4 adjust the current value by +1 and -1 respectively but don't repeat while the button is being held. I was expecting that they'd continue adjusting the level while they were being held but that doesn't appear to be the case.
Here's what my log looks like when buttons are being pressed:
I'm sure I'm missing something here but I'll be damned if I can figure out what it is
Also, I assume that > With this fade determines the time the fade takes in seconds??
Any help, suggestions, guidance, slaps up side the head would greatly appreciated!
