Lutron pro upgrade
question if I upgrade to a Lutron Pro hub will it make the caseta switches show up in Hubitat as well?? or do i just get the pico's??
and whats the process for upgrading???
Yes, the lutron switches also show up in Hubitat. The upgrade process would depend on what you are upgrading from. Do you currently have a Lutron non-pro hub?
Yes I have a Lutron non pro hub with 4 switches and 1 pico
@user5029 Everything except motion detectors connected to the lutron hub will show up in hubitat for direct 100% local control.
You will need to remove them from current hub and add to new hub. Then use telnet to control them from Hubitat.
