I've only used the wireless Picos so far... Can anyone confirm that the wired version of the Picos would be as programmable with HE? Meaning, I can add the wired Pico to the Lutron Pro bridge and use RM to change button behavior?
@alex24x7 Lutron make lots of lighting control devices for different systems. The Pico wired control is for things like low voltage lighting systems, more common in commercial settings. It isn't compatible with the Pro Bridge.
If you want wired Lutron button controllers controllable by Hubitat then the product you want is a RadioRA 2 keypad. The wired keypads are 2 way communication so there are fewer opportunities for communication breakdowns as compared to a transmit-only Pico. But there's a significant investment to get RadioRA 2 system. A Main Repeater is ~$300 +/- on eBay. The keypads are ~$150 +/-
