I have the Lutron pro bridge and some Pico's setup and working great. Was wondering what Lutron motion sensors people are using and what your experience with them have been. I see several different ones on Amazon, all with 10 year battery life.
Looking to get a few corner mounted and/or some ceiling mounted units to replace my Aeotec z-wave sensors.
Only battery powered Lutron motion sensors I'm aware of are RA2. Is that what you're looking for? You would need at least and RA2 Select bridge to use those. I'm using Sylvania Lightify (Centralite) and Xiaomi Aqara (love those little guys).
All are reliable. The Centralite is very fast, and angle of coverage is decent. The Xiaomi are also fast and sensitivity is good. Angle is restricted on the top and bottom. The dog doesn't set those off, but she does trigger the Centralite, and she's a small dog.
Thanks. Specifically looking for Lutron motion sensors that work with the Pro bridge which then works with Hubitat.
Looking for those that HAVE the sensors and whether you like them or not. @bravenel, I think I remember you mentioning that you have some Lutron motion sensors in your house. Any recommendations?
That's what I needed to know. Was trying to get away from z-wave/zigbee for the motion/occupancy sensors. I have several Aeotec gen 4/5 and a few new Xiaomi sensors controlling all of my lighting but was looking for something better/more reliable. The Pico's work so well I figured I would try the Lutron but I guess that's not going to happen!
Really hope they come up with occupancy and window/door sensors for the Caseta system. Really like the sound of a 10 year battery!
I just sent an email to custsvc@lutron.com. I asked them to consider giving users with Caseta products the ability to incorporate RA2 sensors or make the jump to RA2 by taking all of their current switches with them (Too expensive to replace everything now).
I just received a reply from Ed from Lutron support. He says that there are no plans to allow devices, other than Picos, to cross the Caseta / RA2 line. He did say that they will be releasing a Caseta motion sensor (or the ability to add the RA2 sensors) sometime in the coming months.
Maybe if a few more people, say the entire HE community , emails customer support we might be able to invoke some change. custsvc@lutron.com
That's too bad, I do like their RA2 products. Just not at the cost required to switch everything over. I guess having the limited distribution is what helps keep the prices high.
My understanding is that, while RA2 Select works with Lutron occupancy sensors, the RA2 Select hub does not have monitoring events enabled for them - ie, it processes occupancy events within the hub, but does not pass them out via Telnet, so a Radio RA2 repeater would be required to integrate the occupancy sensor with other devices across the Hubitat platform. Is that correct, and if so, is there an alternate way (short of buying a RA2 repeater) to integrate Lutron occupancy sensors?
I read it on the Lutron Caseta forum. I can't post links, but the poster wrote:"The RRA2 Select and occupancy sensor do not have the monitoring events enabled. After some back and forth, Lutron confirmed that they do not, and do not plan on adding that feature. Which means that the RRA2 Select bridge can't be used for this proxy idea."
Have not completely verified it myself -- I installed an occupancy sensor on my Ra2 Select this morning and in limited trials have not been able to see occupany/motion events from it in the log, but I am new to Hubitat, so there is some chance I just don't have it configured correctly.
In Logs isolate on the Lutron Telnet log. Then trip your occupancy sensor. You should see something with ending with "....,2,3" for active and "....,2,4" for inactive.
That's too bad. Lutron is such an old school company, they evidently think that by limiting functionality it supports sales of products. Like you're going to move up to RA2 because of this. To me it's just dumb.
Hello, I've been trying with no success. Have you been able to get your RA2 select system and lutron occupancy sensors to work with the motion control hubitat app? Any tips?
