I am outfitting house with Lutron Caseta ... but I am trying to figure out what the best route is for fan control. So many topics that spiral I am finding it hard to make an informed choice.
I know that Maestro is outside of the Caseta world .. but would the Lutron Maestro fan kit be a good option to use?
Currently in multiple rooms there is a 3 gang switches.
1 switch is a round dimmer for ceiling lights
1 switch is for the light
1 switch is for the power to the fan (ie turn it off then nothing works).
I would like to avoid drywall repair work because I think I can handle the whole thing with 2 lutron switches.
1 lutron caseta in wall dimmer (for ceiling lights)
1 lutron maestro for fan and fan light.
Will I be able to control the fan from hubitat RM? I'm very confused on caseta and maestro .. I don't care if I can't control in the lutron app. I just want to be able to control my "lutron" switches from hubitat RM.
If you need fan controllers you need to go with Lutron's RA 2 select system. Not to be confused with their regular RA 2 product. As of a couple of months ago you could not ad a fan controller to Caseta. The thing that sucks about going RA 2 select over Caseta is that the switches and dimmers are about double the price of Caseta but if you need fan controllers you have to go RA 2 select or the RA 2 system. I researched Lutron pretty extensively and almost went with this system for my house. I ultimately decided to just go with the new Homeseer WD 200 switches instead. Homeseer also just released their fan controllers as well.
As others have said Maestro won’t work with Caseta. I personally have many GE Zwave Fan control switches in my home to control fans. They work great for fans that have separate wires for light on a fan and fan motor. I do have one fan with a sing,e power that I am using the Hampton Bay/King of Fans Zigbee controller. All work great.
Left switch power to FAN
If switch is off the remote doesn't work, If switch is on I can change the fan speeds with remote
Middle switch power to fan LIGHT
If switch is off, remote doesn't work. If switch is on and I turn the light off with the remote then I can't control the light with the switch - if remote turned light off then I can't turn it on with the switch. But if switch is on I can't turn it on with the remote.
Right switch power to ceiling dimmers
This is just the recessed lights in the ceiling nothing to do with fan - so I will put a caseta dimmer in there.
I purchased GE Zwave plus Smart fan control (Fan only).
So
LEFT switch - GE Zwave smart fan control
MIDDLE switch Lutron Caseta Dimmer
RIGHT switch Lutron Caseta Dimmer
Would that be the correct setup? I want the fan light and the ceiling lights to be on different dimmers.
Just trying to make it all work right.
-- or --
Should I just put 1 caseta dimmer on the ceiling lights (RIGHT) and leave the other two (LEFT / MIDDLE) like they are (they won't be used much). then how do I get a gang plate for 2 manual switches and 1 caseta dimmer? (This would be the preferred way of doing it - cheaper, easier). I just can't find a gang plate. (Part of me wants to be able to control the fan and fan light from Hubitat and then when Google Home is available be able to extend that to voice).
It sounds like you fan is designed to be controlled by an existing remote control (either IR or RF), correct? These fans can be a little more troublesome to get to work with smart switches. Fans with pull-chains are usually easier to integrate. I added a Hampton Bay Zigbee Fan controller to the canopy of my simple ceiling fan, which has been working well for my. I actually use a Lutron Pico Remote to control the fan and light through Hubitat. The Pico remote is installed in the wall-plate on the wall, alongside other switches.
For fans that came with a remote control, I believe some users have added additional hardware (like Bond) that can 'speak RF' to the fan, basically imitating the OEM remote control. I don't have any experience with those devices, but I am sure you'll find references to them if you search the forums (like the one below.)
It is usually simpler to replace all of the switches to the Decora (i.e. paddle) style of switches and then get a new faceplate that matches. I have slowly been replacing all of my toggle style switches with a combination of manual and smart decora style switches.
Note: Replacing a manual toggle switch with a manual decora switch is only a few dollars at Home Depot or Lowes.
(I sold the condo about a year ago, leaving a running Hubitat system behind. The new owner took my brief set of instructions, and figured out the whole system on his own. It ran without interruption or update for about 10 months. He finally contacted me when one Zigbee motion sensor needed a new battery, and it wouldn't rejoin. I told him what to do, but he reported that it just started working on its own. He's a happy camper.)
