I am sure it will turn out to be something dumb, but - - -
I have a Lutron Caseta Bridge Pro. There are 4 devices paired to it. They all work, manually and via the Lutron App. But they do not work via Hubitat despite appearing in its device list and looking as though they should work.
I note that on the "command" page for the dimmers "wait" is indicated as "true". Does that mean anything relevant?
I have repeated the installation procedure several times and with the documentation open.
I will be embarassed no matter what but happily so if I can get the things to work.
Did these Lutron devices previously work from Hubitat?
In either event, the most likely reason underlying this issue is that the IP address of your Lutron bridge has changed. Please confirm that it is at the IP address that Hubitat expects it to be.
There should be a Hubitat device called "Lutron Telnet". One of the state variables for this device is the IP address that Hubitat expects the Lutron bridge to have. You can then use the Lutron mobile app to check what the IP address of the bridge really is .... - it should be under Settings -> Advanced -> Integration -> Network Settings. While you're in there, make sure that Telnet Support is turned on.
