I am new to Hubitat. I have an existing Lutron Hub with quite a few devices on it.
I am trying to follow the instructions at Lutron_Integrator#Gathering_required_information
Everything goes fine until I get through step 3. I have set up the IP in DHCP, and Hubitat sees the hub.
At step 4 I only have "Connections." When I go into connections I only see the Google integration, not the Hubitat integration. I have tried several times. I have seen in other threads that it involved hitting "Done" and "Save" so I have made runs through where I was absolutely sure I made it. I am not seeing Telnet anywhere.
I foolishly did not keep a record of which device is associated with each number, and I can't get Lutron to give me the list. I wonder if they have dumbed-down the app. I have tried guessing blind and just assigned dimmer to devices 1, 2, 3, 4, and 5, but that does not seem to work (yes, I know the hub was 1, but I tried it anyway).
If I go to the Hubitat app I see the Lutron integration. Lutron telnet is listed as the first option. However the telnet does not seem to be working, I have tried hitting the initialize button. That increases the "Retry" count, but seems to do nothing else.
