Hi novice here still getting acquainted with home automation. I have the following issue, I installed two lutron caseta dimmer switches and integrated them in HE. Devices appear in the list, I can operate them from the device setting and dashboard. My issue is that the devices do not appear in the apps list. I tried to setup button commands (with ABC, Button Command) the devices are nowhere to be found. They are listed in Rule Machine though. Anyone knows what is happening?
Caséta dimmers are not Button Controllers. So they won’t appear in apps like ABC.
If you set up Caseta switches they should appear in apps as dimmers. They won't appear as buttons unless they are Picos.
