So I went through the lutron integration guide and linked all 30 of my picos/dimmers. I see them under my device list and I also can add them as a button to my dashboard. But when I click the button it says the light should be on but nothing is happening
Dumb question, does the light work when you push the Pico button? Check the log in hubitat and the telnet actions. Compare those logs with the ones the button produces to find the difference and possible cause.
Do you see any errors in the logs? Did you also set the Lutron hub to a static ip in your router? Try rebooting the Lutron hub as well. Note, if you want to AC power cycle the Hubitat, perform a shutdown first in settings.
Is there a way to verify that the caseta hub and the hubitat are connected?
I have caseta hub linked to alexa and that shows up under the caseta app/connections. Should Hubitat also show up as a connection?
If i press the dimmer on and off it works fine manually and through caseta app.
Nothing shows up under device activity log.
If i press on and off within device settings as a command that shows up in the activity log.
im not sure im following. this telnet information. from what i can tell is the telnet selected under caseta app, but thats all i know. I just linked all my devices to the new caseta hub yesterday and now i cant link it to HE
Open Putty and type in your hubs Lutron IP address, click Telnet, click open. (FYI - If your Lutron hubs IP address is not properly assigned none of this will work)
You should be prompted for user name and password use - lutron/integration
I am not sure what other devices you have, but integrations can be a bit trickier than adding a Zigbee or Z-wave devices directly. However if done correctly they pay off well too.
Click your Pico (note the commands displayed in putty) and then click your button on HE, do the same commands appear? Does anything appear when clicking the HE button?
Also check the HE log for the Lutron hub, what does it show when you push those buttons? trying to find where the disconnect is.
Also, after checking it, make sure you click Done. You will find that after first setup or a hub database restore, your Lutron integration may not work unless you open the window and click Done. That for some reason has always been a requirement to get it working again. You don’t have to do it all the time, but I always have to do it after a database restore. So if my Lutron integration doesn’t work, it’s the first thing I try.
