I couldn't find anything about using the Lutron App for geofencing anywhere in the forum. Maybe this is common knowledge for Lutron users, but just in case it is not, I thought I would post this information.
Pros -
reliable virtual presence sensor for hubitat
easy to setup
Good option for an additional app to use for geofencing. (i use this for my 13 year old son's phone)
Cons -
The geofence area is larger than I would prefer (1000ft.)
It can only be used for one phone.
Instructions for setup -
In the Lutron app on the phone you want to use for presence. Go to settings, click on "Arriving/Leaving home" change the first entry to "My Phone"
No need to setup any light scenes for arriving and leaving if you don't want them
Now when you go to settings/ Advanced setting / Send integration report - Your new report should look something like this.
I don't have any scenes set up in lutron. So for me Arriving home is button "1" and Leaving home is button "2"
Go into your Lutron Hubitat integration. You will need to add your Smart hub pro which is seen as a keypad device in Hubitat. It uses ID # "1" .
You should now have a new device in your device list
For the last step. - Add a new virtual device, Select virtual presence sensor, Give it a name.
Now create a new rule in rule machine using button device as the trigger.
I've been using this for 4or 5 weeks now and it has been 100% reliable.
Sorry for the long post. Hopefully this information will be useful for someone.
