Having an issue with the Lutron Integration.
Getting error trying to connect via the app. Switches seem to work but cant get into config to add more.
Below Message [app:49]java.lang.NullPointerException: Cannot get property 'value' on null object on line 123 (mainPage)
Learning so Not sure wha to do! Thanks fo the help!
It looks like you may have manually deleted a lutron device from the driver page without first removing it from your lutron integration. If you don't have many devices setup I would just remove and re add the integration and devices.
All you should have to do is open the Lutron Integration app and hit Done. That will recreate any device that was removed.
Tried Clicking done. Did not seem to work. Trying to avoid starting over.
Thanks for the help!
Could you explain what you mean by "connect via the app"?
