I have a schlage connect with a door sensor that locks automatically whenever I close the door. However, randomly, the door fails to lock even though in my rule event log, I see it being evaluated to True.
I enabled debugging on my lock and found a debug line (which I do not know what it means) that always appears when the lock fails to lock. The exact message is skip cmd: ApplicationBusy(status:0, waitTime:0)
Well, you have the first and only lock I'm aware of that says it's busy rather that actually locking the door as it's supposed to.
I'm not sure what it's doing that makes it busy, can I see more of the logs that lead up to the app busy entry?
I'm confused, In the case of the app busy line, I see a manual unlock before, then an app busy, and then locked.
Is the lock in fact locked or not.
The lock is reporting that it's locked, is that not the case?
Sorry for the confusion. There's a lot of logs as I was opening and closing my door repeatedly to get it to happen randomly. For the one with the app busy line, at the very end, I used Lock command directly on the Device's page before wrapping up since it had not automatically locked.
