I installed a Lutron pro hub and added 2 dimmers and picos. Then set up a dimmer on the motion lighting app which worked great until this AM I can only turn it on manually. I went to the logs 1st (yeah) and I got this error Device 77 does not exist on this hub. It was most likely deleted at some point. Please update your links. Then I removed and reinstalled the switch from HE and the Lutron app. still get the same error.
dev:772023-03-26 08:12:26.748 AMerrorjava.lang.NullPointerException: Cannot invoke method sendMsg() on null object on line 82 (method off)
dev:772023-03-26 08:12:26.717 AMerrorjava.lang.NullPointerException: Cannot invoke method sendMsg() on null object on line 82 (method off)
dev:772023-03-26 08:07:56.219 AMerrorjava.lang.NullPointerException: Cannot invoke method sendMsg() on null object on line 82 (method on)
dev:772023-03-26 08:07:56.184 AMerrorjava.lang.NullPointerException: Cannot invoke method sendMsg() on null object on line 82 (method setLevel)
dev:772023-03-26 07:52:07.047 AMerrorjava.lang.NullPointerException: Cannot invoke method sendMsg() on null object on line 82 (method off)
dev:772023-03-26 07:52:07.018 AMerrorjava.lang.NullPointerException: Cannot invoke method sendMsg() on null object on line 82 (method off)
dev:772023-03-26 07:49:29.115 AMerrorjava.lang.NullPointerException: Cannot invoke method sendMsg() on null object on line 82 (method on)
dev:772023-03-26 07:49:29.050 AMerrorjava.lang.NullPointerException: Cannot invoke method sendMsg() on null object on line 82 (method setLevel)
dev:772023-03-26 07:23:48.345 AMerrorjava.lang.NullPointerException: Cannot invoke method sendMsg() on null object on line 82 (method off)
dev:772023-03-26 07:23:48.317 AMerrorjava.lang.NullPointerException: Cannot invoke method sendMsg() on null object on line 82 (method off)
dev:772023-03-26 07:19:40.693 AMerrorjava.lang.NullPointerException: Cannot invoke method sendMsg() on null object on line 82 (method on)
dev:772023-03-26 07:19:40.661 AMerrorjava.lang.NullPointerException: Cannot invoke method sendMsg() on null object on line 82 (method setLevel)
dev:772023-03-25 05:13:39.243 PMerrorjava.lang.NullPointerException: Cannot invoke method sendMsg() on null object on line 82 (method off)
dev:772023-03-25 05:13:39.211 PMerrorjava.lang.NullPointerException: Cannot invoke method sendMsg() on null object on line 82 (method off)
dev:772023-03-25 05:10:01.957 PMerrorjava.lang.NullPointerException: Cannot invoke method sendMsg() on null object on line 82 (method on)
dev:772023-03-25 05:10:01.924 PMerrorjava.lang.NullPointerException: Cannot invoke method sendMsg() on null object on line 82 (method setLevel)
dev:772023-03-25 04:33:55.159 PMwarndescription logging is: true
dev:772023-03-25 04:33:55.157 PMinfoupdated...
dev:772023-03-25 03:14:11.549 PMinfo Basement Stairs Main switch was turned off [digital]
dev:772023-03-25 03:09:27.173 PMinfo Basement Stairs Main switch was set to 75% [digital]
dev:772023-03-25 03:09:27.169 PMinfo Basement Stairs Main switch was turned on [digital]
dev:772023-03-25 03:06:49.381 PMinfo Basement Stairs Main switch was turned off [physical]
dev:772023-03-25 03:06:44.051 PMinfo Basement Stairs Main switch was set to 49% [physical]
dev:772023-03-25 03:06:38.652 PMinfo Basement Stairs Main switch was set to 93% [physical]
dev:772023-03-25 03:06:34.056 PMinfo Basement Stairs Main switch was set to 100% [physical]
dev:772023-03-25 03:06:34.052 PMinfo Basement Stairs Main switch was turned on [physical]
dev:772023-03-25 03:06:29.041 PMinfo Basement Stairs Main switch was turned off [physical]
dev:772023-03-25 03:05:29.954 PMinfo Basement Stairs Main switch was turned on [digital]
dev:772023-03-25 01:50:08.108 PMinfo Basement Stairs Main switch was turned off [digital]
dev:772023-03-25 01:46:07.218 PMinfo Basement Stairs Main switch was turned on [digital]
dev:772023-03-25 01:44:33.295 PMwarndescription logging is: true
dev:772023-03-25 01:44:33.294 PMinfoupdated...
dev:772023-03-25 01:44:12.015 PMwarndescription logging is: true
dev:772023-03-25 01:44:12.014 PMinfoupdated...
dev:772023-03-25 01:43:46.460 PMwarndescription logging is: true
dev:772023-03-25 01:43:46.459 PMinfoupdated...
dev:772023-03-25 01:43:21.975 PMinfo Basement Stairs Main switch was turned off [digital]
dev:772023-03-25 01:43:20.327 PMinfo Basement Stairs Main switch was turned on [digital]
dev:772023-03-25 01:43:15.490 PMinfo Basement Stairs Main switch was turned off [digital]
dev:772023-03-25 01:43:04.395 PMinfo Basement Stairs Main switch was set to 75% [digital]
dev:772023-03-25 01:43:04.392 PMinfo Basement Stairs Main switch was turned on [digital]
dev:772023-03-25 01:38:46.373 PMinfo Basement Stairs Main switch was turned off [physical]
dev:772023-03-25 01:38:22.979 PMinfo Basement Stairs Main switch was set to 50% [digital]
dev:772023-03-25 01:38:22.976 PMinfo Basement Stairs Main switch was turned on [digital]
dev:772023-03-25 01:36:13.668 PMinfo Basement Stairs Main switch was turned off [physical]
dev:772023-03-25 01:35:53.479 PMinfo Basement Stairs Main switch was set to 100% [physical]
dev:772023-03-25 01:35:53.443 PMinfo Basement Stairs Main switch was set to 50% [digital]
dev:772023-03-25 01:35:53.440 PMinfo Basement Stairs Main switch was turned on [digital]
dev:772023-03-25 01:30:06.480 PMinfo Basement Stairs Main switch was turned off [physical]
