I not sure on that. Originally I would have recommended a MHcozy wifi, since its basically the same as the zigbee on. Unfortunately mine went haywire and was acting eratically. Garage door opening and closing fir 12 hours, lol. Screw MHcozy. I guess you should look at some sort of Shelly, but someone else should recommend which.
You might have missed this earlier in the thread. The Shelly devices I indicated in this post referenced below can function as a momentary relay. They are WiFi devices that are Hubitat-compatible.
Just wanted to keep everybody updated. I bought a POE switch, an outdoor POE switch, a Tp-Link EA225 outdoor WAP, a Shelly 1+, cable, connectors and an Ethernet adapter tool.
My setup is now this.
FiOS router -200' via coax to FiOS extender-POE switch- 300' to outdoor POE switch- 100' to outdoor WAP.
I have Wi-Fi where I need it but I cannot get the Shelly integrated into HE. I've been reading forum posts for hours. Kind of aggravated. Relay works fine via the Shelly app. Nothing via HE.
I think my next step is to just add 2nd hub down there.
You are a god damn hero. The driver worked! It will check state every 2 mins which is cool as I have the Shelly set up as a momentary. Dont know where you pulled that from but thank you so much. Its currently working on the bench and I was able to get it into ActionTiles. Ill report back when I get it in the field.
Ok so I'm going to consider this 99% done. Thanks so much to everyone for the help.
Setup the Shelly as a button with an auto off after 2 seconds. Wired in the relay and tested it from my kitchen panel. She works!
I was a bit nervous as I had to switch the Shelly SSID to the outdoor WAP but the ip address stuck and everything worked despite being on 2 different wireless networks.
The only hiccup I'm having is the driver will sometimes not fetch the state of the Shelly 1 after it's 2 minute setting so the dashboard icon will sometimes always say on as it thinks it's a switch.
I tried to work around this by making a virtual button and using the button controller app to trigger the Shelly. This works but for some reason ActionTiles will not let me add the virtual device as a button. In fact, no virtual devices show up in the device list even after adding them to the ActionTiles app via Hubitat.
Not really sure what that's about but at least I can open the gate from the kitchen now. Just have to hit the button twice.
On the side note, I was trying to start setting up my POE cameras and I learned I am completely ignorant to anything home networking. Something about port forwarding and protocols. My head was spinning last night. 1 or 2 hours of reading and I'm no smarter than when I started. I think I'm just going to put a Ring camera down there for now even though I already bought all the POE cameras. I was attempting to use Tiny Cam Pro to get a url for a Media Tile but I could not get that ■■■■ figured out.
