Looking for recommendations on an energy monitor
I checked the board and really, outside of using Home Assistant with virtual triggers, I don't see how you're gonna do it.
I hate to keep beating a dead horse but once you get to the point of installing the sense, the work of that or Iotawatt is about the same.
You can currently buy the Iotawatt with 2 mains and 10 additional ct clamps for 315 with the ability to add additional clamps at about 20 each.
Direct integration with HE and local control with the benefit of dead on usage reporting. I just don't understand not using Iotawatt.
Now that you'll be a Sense user, I'd recommend you head to the Sense community for help and questions. There are couple of really helpful users over there that can help get you off to the best start possible. And feel free to PM (@dylan.christopherson) me on that site as well. I only check in there once a week or so, but I'll help where I can.
I would very much appreciate a step by step of how you created this graph via webcore. I've never got my head around graphing.
You can also do it in Quick Chart
  1. Open webcore go to the main menu where you can register a browser, chose settings, etc. and select graphs
  2. Choose first option create a new graph
  3. For graph type, select Time Graph.
From that point just go through the steps, it's pretty straight forward. If you have any questions just ask.
If anyone is around Sunny Isles Beach in Florida and wants my Sense with 4 clamps for free
you are welcome at any time to pick it up. Just let me know.
PS.
I am to...o lazy to ship it out.
I'll pay for shipping if you'll send it!!!
Please check yours PM.
If that deal falls through, let me know!
Sorry, @user5035 was first in line so, he will get this toy.
Any sense energy monitor users can you tell me how to get a day by day number for wattage or what my highest wattage use is? Trying to calculate how much solar I would need from a whole entire house. I may be moving to a new property and would like to install solar at the new property but don't know how much solar I would need or how many watts. Your help would be greatly appreciating this matter. That's why I was hoping that we could come up with a way to integrate sense into hubitat so that I could get the total wattage per day.
Not sure about sense, but you can certainly do that with iotawatt
I don't see anything within the app, but there is an option on the website to export data (up to a year at a time) with hourly resolution. This won't get to the "peaks" that you are looking for, but I would recommend a different approach to sizing a solar system. Hopefully update later, have a meeting I need to get to right now.
EDIT: Peaks can get REALLY high, really fast. For example, if you happen to be running the Air conditioner, electric clothes dryer, and a toaster oven at the same time, your peak will be huge. If you average that peak out over something like 15 minutes or an hour, it will still be high but much more manageable. Personally, I would go about sizing a solar/battery system based on the Always On load. This results in the smallest system, but also the shortest ROI because you will be using the full capacity of the system. Sizing a system to meet your peak load will result in the largest system with the longest ROI because you'll have a ton of capacity that is usually sitting idle.
A good "in-between" approach could be to size the system based on your average daily kWh, and some statistical number. For example, in any given year/month, 90% of the days have a total kWh of 15 kWh or less. That number (and your Always On) are fairly easy to get from Sense.
For reference, what would be required to get this data from Iotawatt? I'm envisioning the following:
  1. THe Iotawatt device
  2. A platform (Hubitat or other) to integrate the Iotawatt. Or does it have it's own "native" interface/platform?
  3. A database to store the data. Hubitat can't do this, but perhaps something like InfluxDB?
  4. Some tool to export the data into a common format like a CSC or excel spreadsheet.
I've got no experience with any of these (except Hubitat, of course) so it's a serious question. It just seems like there has to be more to it than simply "Iotawatt can do that."
IoTaWatt has a built-in webserver with both built-in reporting/graphing and the ability to dump the data into influxdb:
https://docs.iotawatt.com/en/master/graphPlus.html#
https://docs.iotawatt.com/en/master/influxDB.html#
There are Hubitat drivers already built to pull data into Hubitat.
The one from ogiewon:
And mine:
Both drivers are using the built-in API on the IoTaWatt device to pull the data. This could also be used for any other homegrown solution:
https://docs.iotawatt.com/en/master/query.html#
IoTaWatt has built-in support to export its data to InfluxDB, Emoncms, and PVOutput. It also has built-in store and forward, thereby accounting for loss of network communications without any loss in the data transfer.
It keeps a local copy of data on its SD card, for I believe up to 5 years.
I was looking at this thread for what to buy, but it seems Iowatta is no longer available for purchase?
“ With recent cost increases in all aspects of production and operations, I’ve decided to discontinue the effort.”
Wow that's really sad. Perhaps someone will take up the torch to keep making them.... What do you think @ogiewon ?
That would be nice! Since it is all Open Source (hardware and software), it is definitely a possibility.
