Looking for a Ceiling fan/light Switch
I am looking for a Z-Wave Ceiling Fan Switch that can control both the fan and a light. I found this model GE Switch but it does not control the light, only the fan. Can anyone recommend a Z-Wave switch that will control both a ceiling fan and the light?
@vincent When they come back in stock the innovelli red fan switch
Yeah, I saw those listed elsewhere and then I checked and saw that they were out of stock. Was hoping there might be an alternative.
I'm currently in the middle of a room remodel. So as it stands now I may just need to install a non z-wave switch for the time being and replace it later down the road.
Is it a dual gang or single gang box?
Currently it's two but I'm changing it to a 3 gang. I need one switch for outdoor flood lights, one for the ceiling fan, and one for a dimmer switch to a set of recessed lights I installed. I don't have room for a 4-gang due to a vent pipe.
Use a pico for the outdoor flood lights. That way you can have 3 actual switches with a 4 gang plate
