I’m trying to do a second Hubitat install at a home I have put in the country. I finally got Starlink so now I can start doing some automation. My first project is a bit ambitious…
I want to control some automatic cables to pump well water to my pond when the level gets low. I have everything figured out except how to monitor the pond level. It’s about 500 feet from the house where the Hubitat is. I was thinking of installing several of these float sensors:
Anndason 6 Pieces Plastic PP Float Switch Fish Tank Liquid Water Level Sensor,Model: DP5200 https://a.co/d/ghXwUYy
Just space the several inches apart and run sprinkler control wires out to them (low voltage, designed to be buried). It’ll be around 3-5 ohms of wire resistance.
Can someone recommend a multi-channel device that can sense 5 ohms vs open circuit reliably that compatible with Hubitat? I use Konnected at my main house for alarm stuff, so that could work, but it’s a bit pricey at $100 for 6 sensing channels.
I guess it’s worth bonus points if someone can recommend a way to do this without needing 500 feet of 10 strand direct bury wire (about $400). But I’m not sure anything wireless will work that far as I don’t have power down at the pond. I may add solar with a battery later just for lighting, but not sure when.
Thanks!
