Forget about the Zwave details page for a minute.
IS THE DEVICE WORKING ON THE DEVICE DETAILS PAGE? Can you control the device from there? Does the status update if you turn the outlet on/off locally with its button?
You've been asked this many times, because it matters in understanding how to proceed / where the issue may be.
Sorry, had an internet outage and other things fall on my lap.
Yes it responds to commands.
Ok that is odd for sure. You could just leave it and it might keep working fine. Personally I would exclude it and pair again. Before you exclude though you need to set smart start up correctly.
Set to boot mode long range.
Set grants to both S2 unauth and S2 auth
Make sure it is within range of the hub. Then when you exclude it, it should reset and pair back again. You might have to manually delete the orphaned device entry afterwards.
Thanks for that info. I'll report back when I get back home from my trip in few days.
The same thing just happened to me.
I've been adding some Z-wave LR devices; it went smoothly.
Today, when I was on the Z-wave Settings Details page, I found a sh**load of what seem to be ghost LR (only) devices!
edit: sorry about the format
edit2: I did a shutdown/power cycle and they went away.
Summary
x0110 (272) LR PER: , RTT Avg: ms, LWR RSSI: N/A
Neighbors: undefined, Route Changes: undefined Unknown
None |
01 -> 0110 100kbps |
0x0111 (273) LR |
PER: , RTT Avg: ms, LWR RSSI: N/A |
Neighbors: undefined, Route Changes: undefined |
Unknown |
None |
01 -> 0111 100kbps |
0x0112 (274) LR |
Unknown |
None |
01 -> 0112 100kbps |
0x0115 (277) LR |
Unknown |
None |
01 -> 0115 100kbps |
0x0119 (281) LR |
Unknown |
None |
01 -> 0119 100kbps |
0x011b (283) LR |
Unknown |
None |
01 -> 011B 100kbps |
0x0121 (289) LR |
Unknown |
None |
01 -> 0121 100kbps |
0x0123 (291) LR |
Unknown |
None |
01 -> 0123 100kbps |
0x0124 (292) LR |
Unknown |
None |
01 -> 0124 100kbps |
0x0125 (293) LR |
Unknown |
None |
01 -> 0125 100kbps |
0x0126 (294) LR |
Unknown |
None |
01 -> 0126 100kbps |
0x0128 (296) LR |
Unknown |
None |
01 -> 0128 100kbps |
0x0129 (297) LR |
Unknown |
None |
01 -> 0129 100kbps |
0x012b (299) LR |
Unknown |
None |
01 -> 012B 100kbps |
0x012d (301) LR |
Unknown |
None |
01 -> 012D 100kbps |
0x012e (302) LR |
Unknown |
None |
01 -> 012E 100kbps |
0x012f (303) LR |
Unknown |
None |
01 -> 012F 100kbps |
0x0130 (304) LR |
Unknown |
None |
01 -> 0130 100kbps |
0x0131 (305) LR |
Unknown |
None |
01 -> 0131 100kbps |
0x0132 (306) LR |
Unknown |
None |
01 -> 0132 100kbps |
0x0135 (309) LR |
Unknown |
None |
01 -> 0135 100kbps |
0x0136 (310) LR |
Unknown |
None |
01 -> 0136 100kbps |
0x0137 (311) LR |
Unknown |
None |
01 -> 0137 100kbps |
0x0138 (312) LR |
Unknown |
None |
01 -> 0138 100kbps |
0x0139 (313) LR |
Unknown |
None |
01 -> 0139 100kbps |
0x013a (314) LR |
Unknown |
None |
01 -> 013A 100kbps |
0x013b (315) LR |
Unknown |
None |
01 -> 013B 100kbps |
0x013c (316) LR |
Unknown |
None |
01 -> 013C 100kbps |
0x013e (318) LR |
Unknown |
None |
01 -> 013E 100kbps |
0x0140 (320) LR |
Unknown |
None |
01 -> 0140 100kbps |
0x0141 (321) LR |
Unknown |
None |
01 -> 0141 100kbps |
0x0142 (322) LR |
Unknown |
None |
01 -> 0142 100kbps |
0x0143 (323) LR |
Unknown |
None |
01 -> 0143 100kbps |
0x0144 (324) LR |
Unknown |
None |
01 -> 0144 100kbps |
0x0145 (325) LR |
Unknown |
None |
01 -> 0145 100kbps |
0x0146 (326) LR |
Unknown |
None |
01 -> 0146 100kbps |
0x0147 (327) LR |
Unknown |
None |
01 -> 0147 100kbps |
0x0148 (328) LR |
Unknown |
None |
01 -> 0148 100kbps |
0x0149 (329) LR |
Unknown |
None |
01 -> 0149 100kbps |
0x014e (334) LR |
Unknown |
None |
01 -> 014E 100kbps |
0x0150 (336) LR |
Unknown |
None |
01 -> 0150 100kbps |
0x0156 (342) LR |
Unknown |
None |
01 -> 0156 100kbps |
0x0157 (343) LR |
Unknown |
None |
01 -> 0157 100kbps |
0x0158 (344) LR |
Unknown |
None |
01 -> 0158 100kbps |
0x0161 (353) LR |
Unknown |
None |
01 -> 0161 100kbps |
0x016e (366) LR |
Unknown |
None |
01 -> 016E 100kbps |
0x0171 (369) LR |
Unknown |
None |
01 -> 0171 100kbps |
0x0174 (372) LR |
Unknown |
None |
01 -> 0174 100kbps |
0x0177 (375) LR |
Unknown |
None |
01 -> 0177 100kbps |
0x0179 (377) LR |
Unknown |
None |
01 -> 0179 100kbps |
0x017b (379) LR |
Unknown |
None |
01 -> 017B 100kbps |
0x017c (380) LR |
Unknown |
None |
01 -> 017C 100kbps |
0x017d (381) LR |
Unknown |
None |
01 -> 017D 100kbps |
0x017e (382) LR |
Unknown |
None |
01 -> 017E 100kbps |
0x017f (383) LR |
Unknown |
None |
01 -> 017F 100kbps |
0x0180 (384) LR |
Unknown |
None |
01 -> 0180 100kbps |
0x0181 (385) LR |
Unknown |
None |
01 -> 0181 100kbps |
0x0186 (390) LR |
Unknown |
None |
01 -> 0186 100kbps |
0x0187 (391) LR |
Unknown |
None |
01 -> 0187 100kbps |
0x0189 (393) LR |
Unknown |
None |
01 -> 0189 100kbps |
0x018a (394) LR |
Unknown |
None |
01 -> 018A 100kbps |
0x018b (395) LR |
Unknown |
None |
01 -> 018B 100kbps |
0x018c (396) LR |
Unknown |
None 01 -> 018C 100kb
