Should work, but if you are not using Hub Security as @Ryan780 is asking about, and it still won't work, you can try this method (but it is essentially the same thing). I've used the method below from time to time. Currently I'm using it until I have a chance to figure out which of my devices is causing the issues.
Use this code from @ogiewon for the HTTP switch.
* HTTP Momentary Switch
* Copyright 2018 Daniel Ogorchock
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Change History:
* Date Who What
* 2018-02-18 Dan Ogorchock Original Creation
metadata {
definition (name: "HTTP Momentary Switch", namespace: "ogiewon", author: "Dan Ogorchock") {
capability "Switch"
capability "Momentary"
preferences {
input(name: "deviceIP", type: "string", title:"Device IP Address", description: "Enter IP Address of your HTTP server", required: true, displayDuringSetup: true)
input(name: "devicePort", type: "string", title:"Device Port", description: "Enter Port of your HTTP server (defaults to 80)", defaultValue: "80", required: false, displayDuringSetup: true)
input(name: "devicePath", type: "string", title:"URL Path", description: "Rest of the URL, include forward slash.", displayDuringSetup: true)
input(name: "deviceMethod", type: "enum", title: "POST, GET, or PUT", options: ["POST","GET","PUT"], defaultValue: "POST", required: true, displayDuringSetup: true)
log.debug(description)
def push() {
//toggle the switch to generate events for anything that is subscribed
sendEvent(name: "switch", value: "on", isStateChange: true)
runIn(1, toggleOff)
//sendEvent(name: "switch", value: "off", isStateChange: true)
runCmd(devicePath, deviceMethod)
def toggleOff() {
def on() {
push()
def off() {
push()
def runCmd(String varCommand, String method) {
def localDevicePort = (devicePort==null) ? "80" : devicePort
def path = varCommand
def body = ""
def headers = [:]
headers.put("HOST", "${deviceIP}:${localDevicePort}")
headers.put("Content-Type", "application/x-www-form-urlencoded")
try {
def hubAction = new hubitat.device.HubAction(
method: method,
path: path,
body: body,
headers: headers
log.debug hubAction
return hubAction
catch (Exception e) {
log.debug "runCmd hit exception ${e} on ${hubAction}"
