I changed the name of a rule but the log keeps using the old name. Bug or am I missing something?
Odd! It does sound like it might be a bug. In which rules engine is this happening? Could you share screenshots of the rule showing its name and of the logs showing the other name?
Also, when you click on the error type (info/Warn/Error/…), does it bring up the right rule that has a different name?
The logs retain the name for a while after the name change (I believe until the last entry using the name is purged off due to age) as the real identifier is probably the device/app ID.
