Locked out of hub variables
I cam across this and a reboot didn't fix it.
We are putting out a hot fix release that will correct this issue. In the meantime, your best bet is to restore a database from before this happened.
would I be ok just leaving it till the fix? I don't really need to get into them right now. I made a lot of dashboard changes since last backup and really don't want to loose it all.
Yes, this should be cleared up when the fix comes out.
Just updated to 2.3..0.113. When i attempted to open a RM5.1 routine, I received this error:
........ and here is the offending statement that ties to the Error message.....
I have rolled back to previous version and my backup. All is good with that release for me.
Please do the following:
  1. Post a screenshot of the rule.
  2. Turn on Action Logging
  3. Run the actions of the rule.
  4. Post a screenshot of those logs.
Ok. Here is the whole rule set from 2.3.0.112...
and the resultant log from the last execution....
Let me know how else I can help.
Update. My issue is also reproducible in 2.3.0.116. I have been able to narrow it down to rules that reference text files as variables ( example %/local/filename%) . I have more that one rulesets where I use this construct. They are all having this issue i.e. throwing the Unexpected Error when opening the ruleset.
I will investigate further...
Update. I was able to employ a workaround. As this issue is specific to referencing %local% file system variables, I was able to set a hub string variable to the contents of my text file and then reference that hub variable in my log/send/speak messages. Once I did this I was able to successfully update to a post 2.3.0.112 release.
