I just successfully paired two Schlage BE469's with Firmware 8.0 without any incident and first time. I've successfully installed Lock Code Manager and successfully added 2 users with PIN to each of the locks. I have a question as it relates to the device details of the locks. I notice a preference for "lockCode Encryption" which is set off by default. I also noticed in the logs that setting the lock codes was in plain text. I can't find any documentation on what turning lockCodes Encryption "on" will actually do. Can someone please shed some light before I enable this? Thank you.
Jason
