That log was from the LCM. Earlier, I did the same thing, and the log showed me results for the lock device. Here's what that log was:
dev:4322022-12-26 20:51:55.851debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:55.848debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:55.845debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:54.766debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:54.763debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:54.760debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:54.301debugfetchLockCode- 2
dev:4322022-12-26 20:51:54.298debugalarmv2.AlarmReport: AlarmReport(alarmLevel:2, alarmType:112, eventParameter:[], numberOfEventParameters:0, zensorNetSourceNodeId:0, zwaveAlarmEvent:14, zwaveAlarmStatus:255, zwaveAlarmType:6)
dev:4322022-12-26 20:51:54.293debugparse: zw device: 15, command: 7105, payload: 70 02 00 FF 06 0E 00 00 , isMulticast: false
dev:4322022-12-26 20:51:53.298debugsetCode(2, null, Test)
dev:4322022-12-26 20:51:51.785debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:51.782debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:51.779debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:50.714debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:50.709debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:50.701debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:50.237debugfetchLockCode- 2
dev:4322022-12-26 20:51:50.233debugalarmv2.AlarmReport: AlarmReport(alarmLevel:2, alarmType:112, eventParameter:[], numberOfEventParameters:0, zensorNetSourceNodeId:0, zwaveAlarmEvent:14, zwaveAlarmStatus:255, zwaveAlarmType:6)
dev:4322022-12-26 20:51:50.230debugparse: zw device: 15, command: 7105, payload: 70 02 00 FF 06 0E 00 00 , isMulticast: false
dev:4322022-12-26 20:51:49.230debugsetCode(2, null, Test)
dev:4322022-12-26 20:51:47.725debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:47.722debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:47.719debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:46.637debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:46.634debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:46.631debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:46.173debugfetchLockCode- 2
dev:4322022-12-26 20:51:46.170debugalarmv2.AlarmReport: AlarmReport(alarmLevel:2, alarmType:112, eventParameter:[], numberOfEventParameters:0, zensorNetSourceNodeId:0, zwaveAlarmEvent:14, zwaveAlarmStatus:255, zwaveAlarmType:6)
dev:4322022-12-26 20:51:46.166debugparse: zw device: 15, command: 7105, payload: 70 02 00 FF 06 0E 00 00 , isMulticast: false
dev:4322022-12-26 20:51:45.158debugsetCode(2, null, Test)
dev:4322022-12-26 20:51:43.641debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:43.638debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:43.635debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:42.566debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:42.563debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:42.559debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:42.098debugfetchLockCode- 2
dev:4322022-12-26 20:51:42.094debugalarmv2.AlarmReport: AlarmReport(alarmLevel:2, alarmType:112, eventParameter:[], numberOfEventParameters:0, zensorNetSourceNodeId:0, zwaveAlarmEvent:14, zwaveAlarmStatus:255, zwaveAlarmType:6)
dev:4322022-12-26 20:51:42.091debugparse: zw device: 15, command: 7105, payload: 70 02 00 FF 06 0E 00 00 , isMulticast: false
dev:4322022-12-26 20:51:41.091debugsetCode(2, null, Test)
dev:4322022-12-26 20:51:39.573debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:39.569debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:39.566debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:38.501debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:38.497debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:38.492debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:38.032debugfetchLockCode- 2
dev:4322022-12-26 20:51:38.028debugalarmv2.AlarmReport: AlarmReport(alarmLevel:2, alarmType:112, eventParameter:[], numberOfEventParameters:0, zensorNetSourceNodeId:0, zwaveAlarmEvent:14, zwaveAlarmStatus:255, zwaveAlarmType:6)
dev:4322022-12-26 20:51:38.024debugparse: zw device: 15, command: 7105, payload: 70 02 00 FF 06 0E 00 00 , isMulticast: false
dev:4322022-12-26 20:51:37.020debugsetCode(2, null, Test)
dev:4322022-12-26 20:51:35.507debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:35.504debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:35.500debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:34.426debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:34.423debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:34.418debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:33.962debugfetchLockCode- 2
dev:4322022-12-26 20:51:33.958debugalarmv2.AlarmReport: AlarmReport(alarmLevel:2, alarmType:112, eventParameter:[], numberOfEventParameters:0, zensorNetSourceNodeId:0, zwaveAlarmEvent:14, zwaveAlarmStatus:255, zwaveAlarmType:6)
dev:4322022-12-26 20:51:33.953debugparse: zw device: 15, command: 7105, payload: 70 02 00 FF 06 0E 00 00 , isMulticast: false
dev:4322022-12-26 20:51:32.951debugsetCode(2, null, Test)
dev:4322022-12-26 20:51:31.442debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:31.440debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:31.437debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:30.371debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:30.368debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:30.365debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:29.895debugfetchLockCode- 2
dev:4322022-12-26 20:51:29.892debugalarmv2.AlarmReport: AlarmReport(alarmLevel:2, alarmType:112, eventParameter:[], numberOfEventParameters:0, zensorNetSourceNodeId:0, zwaveAlarmEvent:14, zwaveAlarmStatus:255, zwaveAlarmType:6)
dev:4322022-12-26 20:51:29.889debugparse: zw device: 15, command: 7105, payload: 70 02 00 FF 06 0E 00 00 , isMulticast: false
dev:4322022-12-26 20:51:28.880debugsetCode(2, null, Test)
dev:4322022-12-26 20:51:27.367debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:27.365debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:27.360debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:26.284debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:26.281debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:26.278debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:25.819debugfetchLockCode- 2
dev:4322022-12-26 20:51:25.816debugalarmv2.AlarmReport: AlarmReport(alarmLevel:2, alarmType:112, eventParameter:[], numberOfEventParameters:0, zensorNetSourceNodeId:0, zwaveAlarmEvent:14, zwaveAlarmStatus:255, zwaveAlarmType:6)
dev:4322022-12-26 20:51:25.812debugparse: zw device: 15, command: 7105, payload: 70 02 00 FF 06 0E 00 00 , isMulticast: false
dev:4322022-12-26 20:51:24.785debugsetCode(2, null, Test)
dev:4322022-12-26 20:51:23.261debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:23.259debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:23.256debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:22.121debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:22.117debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:22.113debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:21.639debugfetchLockCode- 2
dev:4322022-12-26 20:51:21.630debugalarmv2.AlarmReport: AlarmReport(alarmLevel:2, alarmType:112, eventParameter:[], numberOfEventParameters:0, zensorNetSourceNodeId:0, zwaveAlarmEvent:14, zwaveAlarmStatus:255, zwaveAlarmType:6)
dev:4322022-12-26 20:51:21.627debugparse: zw device: 15, command: 7105, payload: 70 02 00 FF 06 0E 00 00 , isMulticast: false
dev:4322022-12-26 20:51:20.711debugsetCode(2, null, Test)
dev:4322022-12-26 20:51:19.562debugalarmv2.AlarmReport: AlarmReport(alarmLevel:2, alarmType:112, eventParameter:[], numberOfEventParameters:0, zensorNetSourceNodeId:0, zwaveAlarmEvent:14, zwaveAlarmStatus:255, zwaveAlarmType:6)
dev:4322022-12-26 20:51:19.496debugparse: zw device: 15, command: 7105, payload: 70 02 00 FF 06 0E 00 00 , isMulticast: false
dev:4322022-12-26 20:51:19.133debugno changes to codeNumber:2, code:null, codeMap:[:]
dev:4322022-12-26 20:51:19.129debugUserCodeReport- cmd: UserCodeReport(userIdentifier:2, userIdStatus:0, userCode:null)
dev:4322022-12-26 20:51:19.090debugparse: zw device: 15, command: 6303, payload: 02 00 , isMulticast: false
dev:4322022-12-26 20:51:16.513debugsetCode(2, null, Test)
