Lock control
When you originally started entering codes, did you enter it in the lock first or in LCM first?
The very 1st one yes. The next ones through the app on my PC
Delete all codes in LCM. clear all lock codes on the lock through the device page (1st 2 one delete as they're reserved) , power cycle the lock (just disconnect battery and then reconnect)
Wait 30 seconds...
Now start adding codes through LCM.
Sometimes LCM will have issues from having previous codes on the lock or if you change from 4 to 6 digits.
Honestly if you have only one lock, you don't even need LCM.
I am still concerned about the incomplete code fetch as indicated by the state variables. Still waiting for the logs that were asked for 3 times up above….
I’ve packed up the device and will be returning it today. I do thank you for all the assistance you have patiently provided.
