Love this little app now that I have more than one z-wave lock. However, as soon as I added a second lock to the LCM app to manage, it crashes immediately with:
groovy.lang.MissingPropertyException: No such property: name for class: java.lang.String on line 1302 (method main)
Delete/add app doesn't change anything.
Tagging @mike.maxwell as I believe he wrote this app.
Can you show me device current states for the new lock?, and can you add new codes from the driver page for the new lock?
Sure thing... took some time to check and optimize my z-wave mesh so each lock responded reliably to commands from the Hubitat.
New lock current state:
Exercising lock/unlock commands via driver page this lock: works reliably
Setting a lock code position/code/name from driver page (using generic z-wave lock driver): no, doesn't seem to do anything
If you can't add/remove a code from the lock driver page, you won't be able to do it from LCM either.
LCM just uses the same commands that are exposed in the driver details.
Please add a fake code to this lock and post a screen shot of the driver detail command and current state sections, you can obscure the lockCodes attribute if need be, i don't need to see that.
