I like the lock code app.... but it's missing something I had in SmartThings. The ability to enable/disable a code via presence. If not home then enable otherwise disable it.
Lock notifications have been in RM since 1.1.7 I believe, and don't require LCM
LCM is for managing codes, there's not much point in reinventing the wheel in regards to actions taken by LCM.
There are some time/day based scheduling items missing currently, other than that I'm collecting use cases for these extensions.
Noted
I'm particularly interested in how reliable these types of restrictions were.
For those that don't know, disabling a code on a lock involves actually telling the lock to delete it, enabling a code is telling the lock to add it in as if it were new.
There is no capability on any lock I've seen to date whereby a given code can remain on the lock, but be disabled.
So there's always a risk that a given code won't be added or deleted, interference, batteries, god knows what...
LCM knows about this, but currently doesn't do anything proactive about it.
So i want to use this but I would need a few more things (and maybe they are in there?)
Days and times for codes.
Expiration and start of codes (code will be enabled on this date/time and end on that date/time)
Notifications of the lock codes being used, who used it, etc. (maybe it can do this?)
Presence isnt so much of an issue for me.
I have been using Rboy Apps smart lock for awhile and it works great, will we be able to tie Lock Code manager to rule machine to run actions when a user unlocks or locks a door?
I have kept my yale Yl220 in Smartthings for these functions, it is near the only thing left there.
for those that want to investigate, install a virtual lock device, load LCM, and have at it...
keep in mind that adding deleting codes on the virtual device is instantaneous, in the real world adding a lock code can take a couple of seconds...
I see so much more risk in a feature like this than value. A secure code should be enough. Keep in mind that such a feature would do nothing to stop the master code from unlocking the door.
