Local wifi device with a GUI
Can I use Maker API for this? It's an ESP module controlling our hot tub.
Temperature control
Pump switch
Bubbles switch
Heat switch
I am sooooo lost when I read any of this stuff about Maker API. Am I miss understanding it's use?
You need to add Hubduino into the hot tub ESP module code for hubitat to see and talk to it.
Yeah.....about that......I barely got the original code set up as it is. I would love to do that but I wouldn't know where to start. I've posted about in that topic too.
In short, the Maker API publishes data about the selected Hubitat devices. It sounds like you are trying to add the ESP module to Hubitat, likely by adding the appropriate library/libraries and linking it to the aforementioned HubDuino app.
Yes and I am not sure how to do that. I have an existing module programed and working. It has OTA updates enabled. I don't have the slightest clue what to change, add, where to add, etc in order to get it to work directly with HE.
