Local self-hosted powerful voice assistant
I just found out that it must be very easy to setup fully local voice recognition assistant that might be used through MakerApi to control Hubitat devices with Whisper.cpp. I have not tried anything yet but i will soon. whisper.cpp/README.md at master · ggerganov/whisper.cpp · GitHub
This will solve one big issue with Alexa/Google voice command that go to the cloud. Using your own local voice recognition stack that is easy to setup and also lightweight to run will not allow your voice recording to leave your local network
So did you try it and does it work?
If so what hardware is required to make this work?
@iskren.p.petkov Almost a year, did you try or get this working?
Sadly no. Way too many things to try and this did not get high prio on my side
