I have seen many references to storing/running pistons locally, but no instructions on how to do it. Is this automatic under Native Webcore, or is a setting hidden somewhere in Webcore's settings?
All webCoRE pistons are stored and executed locally on Hubitat. The only way you can make anything more local is to host the webCoRE "dashboard"/IDE locally, which there are a couple posts vaguely describing how to do, but it has no effect on where pistons are stored or how they execute--on your hub.
Thank you. The posts I read made it sound like it was an option I had to set up.
Are editing response times any faster with a local dashboard?
Likely not as the editing runs in the browser
