Local End Point problem in Rule Machine trigger with more than one event
Hub: C8 Pro platform: 2.5.2.139
I had an automation in Rule Machine with Required Expressions and a single trigger (motion detector active motion) and then lots of actions to turn on lights temporarily. The rule has worked fine for a long time. I just added a Local End Point as a second trigger (motion OR endpoint) but now I can no longer access the trigger Events when editing the rule - nor can I access the Local End Point address, because I can't see it.
When I click the trigger events to open/edit, I just get an empty box:
I tried cloning, and reboot, but nothing allows me to alter it. I'd really rather not have to rebuild the whole rule. Any other tricks to kill the triggers?
Just for grins, try making a new condition. You don’t have to use it anywhere.
See it that changes your trigger issue.
Weird. That fixed it it so that I could see the grid of Trigger Events.
If I click the motion trigger, I can edit it. If I click the end point, it goes back to blank, and stays broken until I edit the unused condition again. It did allow me to delete the local end point though, so at least now I'm hopefully back to where i was before.
Noted.
Additional info: Later last night, I cloned the motion detector rule, and turned that one into an end-point ONLY trigger rule - it works, but if I click the end point, I can see it, but can't edit or delete, or add a new trigger.
