Live Logging to InfluxDB
So was working on something for a few days and figured I would share it. For sometime I have been running a Live Logging collection flow through Node-Red. It basically connects to the websocket for Live Logging and then formats it and writes it to InfluxDB. The there is a Grafana dashboard that access that data and displays it in a way that is very consumable. This dashboard is shown below
A while back I saw the beginning of a driver that attempted to write live logging info out to a syslog Server. I have combined the two ideas and here are the results.
Here is a virtual driver that will connect to the local hub and output it's live logging to InfluxDB
Here is the JSON you can import to Grafana to create the dashboard.
  "__inputs": [
      "name": "DS_INFLUXDB_HUBITAT2",
      "label": "InfluxDB Hubitat2",
      "description": "",
      "type": "datasource",
      "pluginId": "influxdb",
      "pluginName": "InfluxDB"
  "__elements": {},
  "__requires": [
      "type": "grafana",
      "id": "grafana",
      "name": "Grafana",
      "version": "9.4.7"
      "type": "panel",
      "id": "graph",
      "name": "Graph (old)",
      "version": ""
      "id": "influxdb",
      "name": "InfluxDB",
      "version": "1.0.0"
      "type": "panel",
      "id": "table",
      "name": "Table",
      "version": ""
  "annotations": {
    "list": [
        "builtIn": 1,
        "datasource": {
          "uid": "grafana"
        "enable": true,
        "hide": true,
        "iconColor": "rgba(0, 211, 255, 1)",
        "name": "Annotations & Alerts",
        "target": {
          "limit": 100,
          "matchAny": false,
          "tags": [],
          "type": "dashboard"
        "type": "dashboard"
  "description": "Telegraf / InfluxDB / Grafana as syslog receiver",
  "editable": true,
  "fiscalYearStartMonth": 0,
  "gnetId": 12433,
  "graphTooltip": 0,
  "id": null,
  "links": [],
  "liveNow": false,
  "panels": [
      "aliasColors": {},
      "bars": true,
      "dashLength": 10,
      "dashes": false,
      "datasource": {
        "type": "influxdb",
        "uid": "${DS_INFLUXDB_HUBITAT2}"
      "decimals": 0,
      "fill": 1,
      "fillGradient": 0,
      "gridPos": {
        "h": 7,
        "w": 24,
        "x": 0,
        "y": 0
      "hiddenSeries": false,
      "id": 10,
      "interval": "",
      "legend": {
        "alignAsTable": true,
        "avg": true,
        "current": false,
        "max": true,
        "min": false,
        "rightSide": true,
        "show": true,
        "total": true,
        "values": true
      "lines": false,
      "linewidth": 1,
      "links": [],
      "nullPointMode": "connected",
      "options": {
        "alertThreshold": true
      "percentage": false,
      "pluginVersion": "9.4.7",
      "pointradius": 2,
      "points": false,
      "renderer": "flot",
      "seriesOverrides": [
          "alias": "Info",
          "color": "rgb(80, 80, 80)",
          "stack": "A"
          "alias": "Notice",
          "color": "rgb(182, 182, 182)",
          "stack": "A"
          "alias": "Warning",
          "color": "#E0B400",
          "stack": "A"
          "alias": "Error",
          "color": "#FF780A",
          "stack": "A"
          "alias": "Critical",
          "color": "#E02F44",
          "stack": "A"
          "alias": "Alert",
          "color": "#8F3BB8",
          "stack": "A"
          "alias": "Emergency",
          "color": "#8F3BB8",
          "stack": "A"
      "spaceLength": 10,
      "stack": false,
      "steppedLine": false,
      "targets": [
          "alias": "Info",
          "datasource": {
            "type": "influxdb",
          "groupBy": [
              "params": [
                "1m"
              "type": "time"
              "params": [
                "null"
              "type": "fill"
          "measurement": "syslog",
          "orderByTime": "ASC",
          "policy": "default",
          "refId": "A",
          "resultFormat": "time_series",
          "select": [
                "params": [
                  "severity_code"
                "type": "field"
                "params": [],
                "type": "count"
          "tags": [
              "key": "severity",
              "operator": "=",
              "value": "info"
              "condition": "AND",
              "key": "hostname",
              "operator": "=~",
              "value": "/^$hostname$/"
              "condition": "AND",
              "key": "severity",
              "operator": "=~",
              "value": "/^$severity$/"
              "condition": "AND",
              "key": "appname",
              "operator": "=~",
              "value": "/^$appname$/"
              "condition": "AND",
              "key": "message",
              "operator": "=~",
              "value": "/$Query/"
          "alias": "Notice",
          "datasource": {
            "type": "influxdb",
          "groupBy": [
              "params": [
                "1m"
              "type": "time"
              "params": [
                "null"
              "type": "fill"
          "refId": "B",
          "select": [
                "params": [
                  "severity_code"
                "type": "field"
                "params": [],
                "type": "count"
          "tags": [
              "key": "severity",
              "operator": "=",
              "value": "notice"
              "condition": "AND",
              "key": "hostname",
              "operator": "=~",
              "condition": "AND",
              "key": "severity",
              "operator": "=~",
              "condition": "AND",
              "key": "appname",
              "operator": "=~",
              "condition": "AND",
              "key": "message",
              "operator": "=~",
              "value": "/$Query/"
          "alias": "Warning",
          "datasource": {
            "type": "influxdb",
          "groupBy": [
              "params": [
                "1m"
              "type": "time"
              "params": [
                "null"
              "type": "fill"
          "refId": "D",
          "select": [
                "params": [
                  "severity_code"
                "type": "field"
                "params": [],
                "type": "count"
          "tags": [
              "key": "severity",
              "operator": "=",
              "value": "warning"
              "condition": "AND",
              "key": "hostname",
              "operator": "=~",
              "condition": "AND",
              "key": "severity",
              "operator": "=~",
              "condition": "AND",
              "key": "appname",
              "operator": "=~",
              "condition": "AND",
              "key": "message",
              "operator": "=~",
              "value": "/$Query/"
          "alias": "Error",
          "datasource": {
            "type": "influxdb",
          "groupBy": [
              "params": [
                "1m"
              "type": "time"
              "params": [
                "null"
              "type": "fill"
          "refId": "C",
          "select": [
                "params": [
                  "severity_code"
                "type": "field"
                "params": [],
                "type": "count"
          "tags": [
              "key": "severity",
              "operator": "=",
              "value": "err"
              "condition": "AND",
              "key": "hostname",
              "operator": "=~",
              "condition": "AND",
              "key": "severity",
              "operator": "=~",
              "condition": "AND",
              "key": "appname",
              "operator": "=~",
              "condition": "AND",
              "key": "message",
              "operator": "=~",
              "value": "/$Query/"
          "datasource": {
            "type": "influxdb",
          "groupBy": [
              "params": [
                "1m"
              "type": "time"
              "params": [
                "null"
              "type": "fill"
          "refId": "E",
          "select": [
                "params": [
                  "severity_code"
                "type": "field"
                "params": [],
                "type": "count"
          "tags": [
              "key": "severity",
              "operator": "=",
              "value": "crit"
              "condition": "AND",
              "key": "hostname",
              "operator": "=~",
              "condition": "AND",
              "key": "severity",
              "operator": "=~",
              "condition": "AND",
              "key": "appname",
              "operator": "=~",
              "condition": "AND",
              "key": "message",
              "operator": "=~",
              "value": "/$Query/"
          "alias": "Alert",
          "datasource": {
            "type": "influxdb",
          "groupBy": [
              "params": [
                "1m"
              "type": "time"
              "params": [
                "null"
              "type": "fill"
          "refId": "F",
          "select": [
                "params": [
                  "severity_code"
                "type": "field"
                "params": [],
                "type": "count"
          "tags": [
              "key": "severity",
              "operator": "=",
              "value": "alert"
              "condition": "AND",
              "key": "hostname",
              "operator": "=~",
              "condition": "AND",
              "key": "severity",
              "operator": "=~",
              "condition": "AND",
              "key": "appname",
              "operator": "=~",
              "condition": "AND",
              "key": "message",
              "operator": "=~",
              "value": "/$Query/"
          "alias": "Debug",
          "datasource": {
            "type": "influxdb",
          "groupBy": [
              "params": [
                "1m"
              "type": "time"
              "params": [
                "null"
              "type": "fill"
          "refId": "G",
          "select": [
                "params": [
                  "severity_code"
                "type": "field"
                "params": [],
                "type": "count"
          "tags": [
              "key": "severity",
              "operator": "=",
              "value": "debug"
              "condition": "AND",
              "key": "hostname",
              "operator": "=~",
              "condition": "AND",
              "key": "severity",
              "operator": "=~",
              "condition": "AND",
              "key": "appname",
              "operator": "=~",
              "condition": "AND",
              "key": "message",
              "operator": "=~",
              "value": "/$Query/"
      "thresholds": [],
      "timeRegions": [],
      "title": "syslog count",
      "tooltip": {
        "shared": true,
        "sort": 0,
        "value_type": "individual"
      "type": "graph",
      "xaxis": {
        "mode": "time",
        "show": true,
        "values": []
      "yaxes": [
          "decimals": 0,
          "format": "none",
          "label": "Messages / min",
          "logBase": 1,
          "show": true
          "format": "short",
          "logBase": 1,
          "show": false
      "yaxis": {
        "align": false
      "datasource": {
        "type": "influxdb",
      "description": "",
      "fieldConfig": {
        "defaults": {
          "color": {
            "mode": "thresholds"
          "custom": {
            "align": "left",
            "cellOptions": {
              "type": "auto"
            "filterable": false,
            "inspect": true
          "mappings": [],
          "thresholds": {
            "mode": "absolute",
            "steps": [
                "color": "dark-purple",
                "value": null
                "color": "dark-red",
                "value": 2
                "color": "dark-orange",
                "value": 3
                "color": "dark-yellow",
                "value": 4
                "color": "rgb(150, 150, 150)",
                "value": 5
                "color": "rgb(51, 51, 51)",
                "value": 6
                "color": "rgb(5, 5, 5)",
                "value": 7
        "overrides": [
            "matcher": {
              "id": "byName",
              "options": "severity_code"
            "properties": [
                "id": "mappings",
                "value": [
                    "options": {
                      "0": {
                        "text": "Emergency"
                      "1": {
                        "text": "Alert"
                      "2": {
                        "text": "Critical"
                      "3": {
                        "text": "Error"
                      "4": {
                        "text": "Warning"
                      "5": {
                        "text": "Notice"
                      "6": {
                        "text": "Info"
                      "7": {
                        "text": "Debug"
                    "type": "value"
                "id": "custom.cellOptions",
                "value": {
                  "mode": "gradient",
                  "type": "color-background"
                "id": "custom.width",
                "value": 119
            "matcher": {
              "id": "byName",
              "options": "Time"
            "properties": [
                "value": 163
            "matcher": {
              "id": "byName",
              "options": "hostname"
            "properties": [
                "value": 194
            "matcher": {
              "id": "byName",
              "options": "appname"
            "properties": [
                "value": 330
      "gridPos": {
        "h": 24,
        "w": 24,
        "x": 0,
        "y": 7
      "id": 12,
      "options": {
        "footer": {
          "countRows": false,
          "fields": "",
          "reducer": [
            "sum"
          "show": false
        "showHeader": true,
        "sortBy": [
            "desc": true,
            "displayName": "Time"
      "targets": [
          "datasource": {
            "type": "influxdb",
          "groupBy": [
              "params": [
                "hostname"
              "type": "tag"
              "params": [
                "appname"
              "type": "tag"
          "refId": "A",
          "resultFormat": "table",
          "select": [
                "params": [
                  "severity_code"
                "type": "field"
                "params": [
                  "message"
                "type": "field"
          "tags": [
              "key": "hostname",
              "operator": "=~",
              "condition": "AND",
              "key": "appname",
              "operator": "=~",
              "condition": "AND",
              "key": "severity",
              "operator": "=~",
              "condition": "AND",
              "key": "message",
              "operator": "=~",
              "value": "/$Query/"
      "title": "Syslog Messages",
      "type": "table"
  "refresh": "",
  "revision": 1,
  "schemaVersion": 38,
  "style": "dark",
  "tags": [],
  "templating": {
    "list": [
        "allValue": "",
        "current": {},
        "datasource": {
          "type": "influxdb",
        "definition": "SHOW TAG VALUES FROM syslog WITH KEY=appname",
        "hide": 0,
        "includeAll": true,
        "label": "Appname",
        "multi": true,
        "name": "appname",
        "options": [],
        "query": "SHOW TAG VALUES FROM syslog WITH KEY=appname",
        "refresh": 2,
        "regex": "",
        "skipUrlSync": false,
        "sort": 1,
        "tagValuesQuery": "",
        "tagsQuery": "",
        "type": "query",
        "useTags": false
        "allValue": "",
        "current": {},
        "datasource": {
          "type": "influxdb",
        "definition": "SHOW TAG VALUES FROM syslog WITH KEY=hostname",
        "hide": 0,
        "includeAll": true,
        "label": "Hostname",
        "multi": true,
        "name": "hostname",
        "options": [],
        "query": "SHOW TAG VALUES FROM syslog WITH KEY=hostname",
        "refresh": 2,
        "regex": "",
        "sort": 1,
        "tagsQuery": "",
        "type": "query",
        "useTags": false
        "allValue": "",
        "current": {},
        "datasource": {
          "type": "influxdb",
        "definition": "SHOW TAG VALUES FROM syslog WITH KEY=severity",
        "hide": 0,
        "includeAll": true,
        "label": "Severity",
        "multi": true,
        "name": "severity",
        "options": [],
        "query": "SHOW TAG VALUES FROM syslog WITH KEY=severity",
        "refresh": 2,
        "regex": "",
        "sort": 0,
        "tagsQuery": "",
        "type": "query",
        "useTags": false
        "current": {
          "selected": false,
          "text": "",
          "value": ""
        "description": "Querystring",
        "hide": 0,
        "label": "MessageQuery",
        "name": "Query",
        "options": [
            "selected": true,
            "text": "",
            "value": ""
        "query": "",
        "type": "textbox"
  "time": {
    "from": "now-1h",
    "to": "now"
  "timepicker": {
    "refresh_intervals": [
      "5s",
      " 10s",
      " 30s",
      " 1m",
      " 5m"
    "time_options": [
      "5m",
      "15m",
      "1h",
      "6h",
      "12h",
      "24h",
      "2d",
      "7d",
      "30d"
  "timezone": "",
  "title": "Syslog Copy Hubitat Dev",
  "uid": "sa3XsKL4k",
  "version": 6,
  "weekStart": ""
This driver combined with this dashboard for Grafana will give you what you see above. You do need to have a working InfluxDB v2 instance, and use a Auth Token for access. I don't have a 1.8 version of InfluxDB anymore. The Grafana dashboard will need to be updated to point to the correct DB once installed as well. If someone wants to actively test a Influx 1.x version I can make the appropriate changes for someone to validate. Just let me know.
What sort of impact does this have on the hub hooking into the logs like this? Have you seen any side effects? Seems like it might cause a bunch of extra processing.
I was very concerned about this to, but because the activity all happens in one method I feel pretty confident in the device stats I got during testing. It showed the cpu was pretty low for a device that talks across the lan. The bottom device is this InfluxDB Syslog virtual device writing data to my local InfluxDB instance. So using .09% of cpu isn't bad. And this when the hub hasn't even been running for 24 hours so it should continue to go down some. It isn't a cpu friendly as say a Zwave or Zigbee device, but it certainly could be allot worse.
What I can't be certain of is the impact if you are generating 10s of db logs per second. I don't think I generally do that as i have a fair amount of debug logging turned off.
I've set up InfluxDB and the virtual device, but it doesn't seem to be working.
Could you give me some pointers on how to find the issue?
I can reach InfluxDB on port 8086 from the browser and do things.
Windows firewall is open for TCP and UDP 8086
(First time using InfluxDB so maybe something there to check...)
This is designed to work with Influxdb 2.x. Make sure you generate a token that has full access to the DB you want to write to and populate the configuration values based on your install there really isn't much to it.
Are you getting any errors?
It was a network issue.
Once I have set "Enable debug logging" to true for the InfluxDB Logger device then I could see that it was a connection issue.
For the record I've installed InfluxDB on a VM and set port forwarding through VirtualBox, but apparently something was missing. Once I've put InfluxDB on the host machine the connection worked fine.
FYI. !!!
It was found today with 2.3.7.138 that the InfluxDB Live Logging driver here may have issues in very busy environments. When the level of activity into the live logging grows to a certain point the driver will start to trigger alerts "Device ### has ### pending asynchronous HTTP requests"
This shouldn't cause any issues other then delaying the logging getting to the external database. i will see if i can provide a method of queueing the calls to prevent this from happening. If the number starts to climb though you may want to disable the device until i can release a update
I just posted a update to this driver to allow it to Queue the records to post to the DB. This will prevent the issue in the previous post. If you update the driver please go into the device and click on save and then click the initialize button. to make sure any new preferences values are set for Queue size, Time between post attempts, and Max Backlog.
My influx server is no longer receiving content from HE. Graphs coming out of Grafana alerted me but initially I thought it had something to do with me adding some new switches and didn't think about it.
Today I did look into it. The HE hub is responding poorly - I'm getting a 408 error server side basically saying 'client time out' to over simplify.
It just began in the last 10 days - coinciding with Matter stuff and changes happening lately. At this same time, I've been running MQTTT and Home Assistant to access Aquara devices and drivers I've been working on - these run on a VM on my Synology NAS. I' running Portainer as well,
My NAS isn't at fault as far as I can tell, although there is additional network traffic that is negligible being added at the NAS from the VM's for the MQTTT.
Are there any tweaks or adjustments that can be made that might improve network performance HE or Infludb Logger side? I'm bouncing my hub now, but don't have high expectations.
I’m not sure what this means, it could refer to Matter stuff and changes happening lately in your home environment?
But if you’re referring to an updated hub firmware, you can always consider rolling back to the firmware version that was running before the issue started, to see if that resolves the problem.
@marktheknife thanks for the suggestion - I shy away from debugging HE nowadays if that was even the fault source.
Happy to note there is NTF. A reboot of the HE fixed the problem.
Then what was it you wanted from posting this. If you are getting 408 from the hub, it probably is at a lower level then the driver i provided. That said if your hub started to fail to write to the DB and it never recovered. Ie your influd DB instance failed eventuall problems could occur.
@mavrrick58 - the initial post asked for suggestion on possible performance adjustments to the HE network - apps that might impact, tuning of any sort etc.
I then said ' NTF' - I came back to post that there was a possible relationship to my working on matter, TPLink/KASA.
The 408 is not from the hub, its a response from the server logged on the hub. I've moved on. thanks.
What does NTF mean?
My guess would be no trouble found.
So one question if you don't mind. Is this about the Live Logging driver from this thread, or Influx Db Logger. The reason i ask is the screenshot you provides shows a backlog being processes. The Live Logging driver would be cleared with a restart of the hub.
the live logging initially demonstrated the backlog. I enabled debug, and after the reboot you can see the count clearing - I only snapped a portion of it to show the success. I had been concerned that the reboot would loose the backlog but clearly demonstrated was the fulfilling 'countdown'. :).
I just reviewed the code and those log entries are from the Smartapp InfluxDB Logger. The driver that this thread is about generates similar, but different logging output and calls out that it is posting log entries instead of event data.
That said those log entries do highlight you had some kind of issue posting entries into your InfluxDB Database and eventually that would cause very bad things to happen if not addressed. I would suggest setting up the notification option with InfluxDB Logger so you know you are having a build up of backlog.
The driver this thread is about doesn't store the data in the database so the data was lost as soon as the restart occured. I did that intentionally because of a few things unique to devices vs smart apps. But that also means this driver would consume memory for as long as it is storing more and more record to try to post the next time it is able to. Eventually the backlog purge process would kick in to prevent catastrophic events fdom being caused by the driver though.
The key take away here is don't leave it for a week or so before addressing and set good max backlog values for both the InfluxDBLogger smartapp and the InfluxDB Hubitat Live Logging driver from this thread. You will loose data eventually but those values are there to keep problems from happening.
Generally speaking when I have seen something similar it was caused by excessive hub load that caused issues with the job scheduler. The result of the scheduler getting borked was jobs got stuck in kind of a partial process state. This could also happen if the hub sends a update to the InfluxDB server and for some reason it fails to send a responds. It is hard to pin down.
I would suggest you do a restart of the hub with the advanced option enabled to rebuild the database on restart. That is effectively a soft reset to cleanup the DB.
thank you for you reply.
having 9000 backlog was a surprise - it highlights just how many data points are being covered. but I did catch it in time. I recognize what you said as being 'data lost' but thankfully it didn't prove true in my case - the backlogger held my data at the HE side, and once I resolved (sheer luck guessing at a reboot of the HE) the connection to Influxdb recovered, and my data spooled off to its proper destination. A clear Kudo's moment to the smart person who wrote that code.
I'm safe - I may put up a logger notification should I hit 7500 or something but loosing the up's and downs of my house temps, sunrise- sunset twilight times and o2 PM data isn't a life ending thing for me. I don't have a wife here to yell at me so ... I stumble on!
thanks again for your assistive responses.
Is this dashboard still valid? I already had things set up and I have the Hub Information dashboard working correctly. Now I'm trying to add HE logs. I've confirmed that the log data is in influxdb and is getting into Grafana. But when I import your dashboard all I get is No Data.
Looking at the json for the panels, the entries in "datasource" appear to be correct and match the other dashboard that's working. Yet I get nothing.
Probably something stupid, but I only know enough about Grafana to be dangerous.
