Where can I find list of device variables to use in WeCore or Rules Machine? %Var%. Example code from open was %What%. Or Name of person associated with %whatCodesName%?
TIA
Tony Mast
TIA
Tony Mast
Long story short...those aren't available readily, but you can make them. There's a few global variables available to RM like %device%, %value%, %text%, %time%, and %date%. Anything else would need to be set to a local variable that could then be elsewhere in the rule or a hub variable to be used in other rules.
Rule Machine will show the list if you set up a Send Notification action (which is where you would ordinarily use them).
Use %device% to include event device name, %value% to include event value, %text% to include event description text, %time% to include event time, %date% to include event date, %now% for current time. To include a variable value use %variable-name%.
Rule Machine also has a few "built-in" variables local to each rule that refer to the last device event, usually the most recent trigger event (except as below, or if the trigger was not a device — a schedule, a hub/location event, manually running rule actions or running from another rule, etc., in which case these variables are not guaranteed to have a speciifc value). These can be referred to in string inputs using:
%device%: name of the device that generated the event (or "timeout" after a "Wait..." action if a timeout is specified on a wait and the next action is reached because the timeout expires)%value%: the value of the event (e.g., could be "off" for a switch)%text%: the descriptionText property for the event (as provided by the driver, often in a format resembling "Living Room switch is off")%date%: the date the event was generated%time%: the time the event was generated%now%: the current time (this value is always available and not related to any specific trigger or event)This topic was automatically closed 365 days after the last reply. New replies are no longer allowed.
