Linking Hubitat to Home Assistant to be able to build nice UIs
Is this possible? I want to sync all my Hubitat connected devices to a Home Assistant instance so that I can then build nice UIs and sync device states between the two.
Will I need to have Zigbee/Zwave dongle on the HA instance even though it won't be used?
Yes. Use the following integration for HA.
There is an unofficial Hubitat integration you can install manually or using HACS: GitHub - jason0x43/hacs-hubitat: A Hubitat integration for Home Assistant. This gets you Hubitat devices into Home Assistant via Maker API on Hubitat, and it should do what you want. No need for Z-Wave or Zigbee radios on Home Assistant then--the devices live on Hubitat, so it doesn't matter.
EDIT: This is the same integration as the above, just a different link.
EDIT 2: This is literally all I use Home Assistant for, and I've barely even customized the UI--just some history graphs (and current states for some devices) with a minimum amount of effort from me. :slight_smile:
I'm up and running and loving how flexible Lovelace is. I played with Home Assistant 3-4 years ago before settling on Hubitat and its come a long way since then. I already have a dashboard up and it's looking great already.
Plenty more to do because I have hundreds of devices but it's going to be fun and flexible.
I'll stick with Hubitat for everything other than dashboards.
