I have two Habitat hubs and try to link a Sinope water valve to the master hub. When I try to select the device in the app Link to hub, I can't find the valve.
How can I link this device?
If you want to link devices between hubs, use Hub Mesh. On the device page there is a slider that says hub mesh, it can be enabled and disabled. Once enabled you can then go to the hub you wish to use it on and in settings > Hub Mesh you can select which devices on the mesh you would like to use with that hub.
Yes that is what I tried to. I can't find the other hub under linked devices. The are in the same ip range (192.168.1.135 and 192.168.1.71)
To clarify:
Are you using Hub Mesh, or
Are you using "Hub Link / Link to Hub"
They are two two completely different built-in apps.
Hub Link / Link to Hub does not support valves (as far as I can remember). Hub Mesh does.
I try Hub Link app first. Then I realized that water valve not was supporten. Then I try Hub Mesh and there I can't find the other hub I want to connect.
You should not be looking for the other hub but for the device.
1st, enable hub mesh on the device page of the valve you want to share.
Then go to settings > hub mesh on the master hub and select linked devices at the top of page.
Look under the available devices list for the hub with the valve. The valve you enabled hub mesh on should be listed. Select the + sign next to device and it will ask if you want to add it to the master hub. That's it.
