Noob to HE trying to get away from Samsung ST.
Linear GD00Z-8 works now but I can't seem to "authorize" it so it appears in device list for tiles and rules.
How do I integrate it into Rule Machine? Will it do that?
In the apps page select the dashboard you want to add it to and then choose the device from the dropdown.
Then go into the dasboards and add a tile with the GD00Z-8 and Garage (control).
If the device has been added to the hub it should be available to RM, shouldn't need to do anything else.
Adding to the dashboard then what is posted above.
