I recently purchased 10 iris v2 sensors and a hubitat. Loving every minute of it and still learning.
I have alot of cats in the house and they keep tripping my Sensor to the office. I have it mounted as high up as I can on the door frame. Is there anyway to limit the detection area? Some way to cover the middle piece so it only triggered right in front of it? I'm sure someone here has devised something
Thanks!
I have a roll of White 'electrical tape' from Home Depot.
I disassemble the Sensor, then I use a piece of tape about an inch long and wrap it around the dome. It extends out beyond the dome by about half an inch.
Just using the sensor to turn lights on in the office when someone walks in. I just need to limit its field of view. Ideas here are stellar. Thanks everyone!
I took the case of the sensor apart and put a small piece of heat shrink tube on the sensor and carefully shrunk around the edge of the sensor just a little to make it snug. Then put the case back together.
This created a very narrow sensor area.
Also, standard sport tape you buy in any pharmacy works fine to blind out a bit of the «view glass» on the motion sensor too.
Just another tip.
RogerThat
Thanks for that. I'm looking at the Pex modification but was thinking that 3/4" would be too large. From Mike's old post;
"2015-10-15. So I replaced the tube shown above with a 3/8" OD by 1" tube, now I get 100% success on triggering. The detection zone is quite a bit larger, maybe 8-12 inches now."
Have you considered the zone motion controller app? you would need a couple of sensors in each room. I believe the way it works is that both sensors have to see the motion before it triggers an event. Perhaps with something small like an animal - it might be harder to trigger 2 sensors ( carefully positioned) than just 1.
uncertain but worth a try.
mac
