I have a simple RL rule that turns on my dressing room light if motion in the bedroom. I've now added a relay to control the hot water recirculation pump in my bathroom so would like the RL rule to also turn on the pump for 2 mins but not to do it again for at least 30 mins as the water will be still warm in the pipes.
Well just in case helpful for others I did this by adding a separate simple rule. This is set to turn on the relay (Qubino) to run the hot water circulation pump when motion detected in either of 2 upstairs bathrooms. Then after this there is a wait for 30 mins before doing anything else. So easy.
In the Qubino relayt setup I have it to auto-off after 2 mins as that pump would never need to run for longer.
