Lights set to wrong levels with Motion Lighting
Just started experiencing a weird issue with motion lighting. I only have two light levels programmed in my motion lighting app. 99%, and 40%. Hubitat will regularly set my lights to odd levels, such as 6%, or 14%, which I don't have programmed anywhere. You can see in the log where the app tries to set the light to the correct level, but the lights set to the wrong level.
Office Light Switch Log
dev:582022-12-09 07:44:54.644 AMinfoOffice lights was set to 6% [digital]
dev:582022-12-09 07:35:43.971 AMinfoOffice lights was set to 10% [digital]
dev:582022-12-09 07:35:43.968 AMinfoOffice lights was turned on [digital]
dev:582022-12-09 03:00:17.856 AMinfoOffice lights was turned off [digital]
dev:582022-12-09 12:00:45.707 AMinfoOffice lights was set to 14% [digital]
dev:582022-12-09 12:00:45.704 AMinfoOffice lights was turned on [digital]
dev:582022-12-08 10:12:00.701 PMinfoOffice lights was turned off [digital]
dev:582022-12-08 07:00:32.202 PMinfoOffice lights was set to 40% [digital]
dev:582022-12-08 06:32:21.420 PMinfoOffice lights was set to 99% [digital]
dev:582022-12-08 06:30:23.835 PMinfoOffice lights was set to 80% [digital]
dev:582022-12-08 06:28:47.170 PMinfoOffice lights was set to 15% [digital]
Motion Lighting App Log
app:2252022-12-09 07:44:02.033 AMinfoSetting dimmers [Office lights] to 99
app:2252022-12-09 07:44:02.027 AMinfoMotion active: Office sensor
app:2252022-12-09 07:43:51.551 AMinfoDelaying off for 120 minutes
app:2252022-12-09 07:43:51.511 AMinfoMotion inactive: Office sensor
app:2252022-12-09 07:35:25.263 AMinfoSetting dimmers [Office lights] to 99
app:2252022-12-09 07:35:25.250 AMinfoMotion active: Office sensor
app:2252022-12-09 07:00:00.219 AMinfoNot turning on: lights not on at mode change
app:2252022-12-09 07:00:00.178 AMinfoMode change to Day
app:2252022-12-09 03:00:17.907 AMinfoOffice lights was turned off
app:2252022-12-08 11:26:19.819 PMinfoNot turning off: lights not on
app:2252022-12-08 11:26:19.810 PMinfoMotion inactive: Office sensor
app:2252022-12-08 11:21:59.398 PMinfoNot turning on: in wrong mode Night
app:2252022-12-08 11:21:59.389 PMinfoMotion active: Office sensor
app:2252022-12-08 11:21:42.799 PMinfoNot turning off: lights not on
app:2252022-12-08 11:21:42.791 PMinfoMotion inactive: Office sensor
app:2252022-12-08 11:19:28.135 PMinfoNot turning on: in wrong mode Night
app:2252022-12-08 11:19:28.126 PMinfoMotion active: Office sensor
app:2252022-12-08 11:18:55.795 PMinfoNot turning off: lights not on
app:2252022-12-08 11:18:55.788 PMinfoMotion inactive: Office sensor
app:2252022-12-08 11:17:10.362 PMinfoNot turning on: in wrong mode Night
app:2252022-12-08 11:17:10.352 PMinfoMotion active: Office sensor
app:2252022-12-08 11:06:46.528 PMinfoNot turning off: lights not on
app:2252022-12-08 11:06:46.521 PMinfoMotion inactive: Office sensor
app:2252022-12-08 11:05:03.989 PMinfoNot turning on: in wrong mode Night
app:2252022-12-08 11:05:03.980 PMinfoMotion active: Office sensor
app:2252022-12-08 11:04:10.710 PMinfoNot turning off: lights not on
app:2252022-12-08 11:04:10.702 PMinfoMotion inactive: Office sensor
app:2252022-12-08 11:02:00.847 PMinfoNot turning on: in wrong mode Night
app:2252022-12-08 11:02:00.839 PMinfoMotion active: Office sensor
app:2252022-12-08 11:00:46.704 PMinfoNot turning off: lights not on
app:2252022-12-08 11:00:46.697 PMinfoMotion inactive: Office sensor
app:2252022-12-08 10:54:57.472 PMinfoNot turning on: in wrong mode Night
app:2252022-12-08 10:54:57.456 PMinfoMotion active: Office sensor
app:2252022-12-08 10:53:21.657 PMinfoNot turning off: lights not on
app:2252022-12-08 10:53:21.647 PMinfoMotion inactive: Office sensor
app:2252022-12-08 10:31:57.139 PMinfoNot turning on: in wrong mode Night
app:2252022-12-08 10:31:57.130 PMinfoMotion active: Office sensor
app:2252022-12-08 10:22:39.518 PMinfoNot turning off: lights not on
app:2252022-12-08 10:22:39.511 PMinfoMotion inactive: Office sensor
app:2252022-12-08 10:14:12.994 PMinfoNot turning on: in wrong mode Night
app:2252022-12-08 10:14:12.986 PMinfoMotion active: Office sensor
app:2252022-12-08 10:13:56.435 PMinfoNot turning off: lights not on
app:2252022-12-08 10:13:56.426 PMinfoMotion inactive: Office sensor
app:2252022-12-08 10:12:00.741 PMinfoOffice lights was turned off
app:2252022-12-08 10:11:59.359 PMinfoTurning off lights
app:2252022-12-08 10:04:33.292 PMinfoNot turning on: in wrong mode Night
app:2252022-12-08 10:04:33.281 PMinfoMotion active: Office sensor
app:2252022-12-08 10:00:00.168 PMinfoNot turning on dimmer: wrong dimmer mode Night
app:2252022-12-08 10:00:00.163 PMinfoMode change to Night
app:2252022-12-08 09:51:59.358 PMinfoDelaying off for 20 minutes
app:2252022-12-08 09:51:59.318 PMinfoMotion inactive: Office sensor
app:2252022-12-08 09:50:41.403 PMinfoSetting dimmers [Office lights] to 40
app:2252022-12-08 09:50:41.398 PMinfoMotion active: Office sensor
app:2252022-12-08 09:50:01.327 PMinfoDelaying off for 20 minutes
app:2252022-12-08 09:50:01.297 PMinfoMotion inactive: Office sensor
app:2252022-12-08 09:45:57.256 PMinfoNot turning off: motion active
app:2252022-12-08 09:26:11.538 PMinfoSetting dimmers [Office lights] to 40
app:2252022-12-08 09:26:11.526 PMinfoMotion active: Office sensor
app:2252022-12-08 09:25:57.248 PMinfoDelaying off for 20 minutes
app:2252022-12-08 09:25:57.195 PMinfoMotion inactive: Office sensor
app:2252022-12-08 09:23:42.122 PMinfoNot turning off: motion active
app:2252022-12-08 09:04:39.269 PMinfoSetting dimmers [Office lights] to 40
app:2252022-12-08 09:04:39.263 PMinfoMotion active: Office sensor
app:2252022-12-08 09:03:42.106 PMinfoDelaying off for 20 minutes
app:2252022-12-08 09:03:42.063 PMinfoMotion inactive: Office sensor
app:2252022-12-08 09:00:51.716 PMinfoSetting dimmers [Office lights] to 40
app:2252022-12-08 09:00:51.710 PMinfoMotion active: Office sensor
app:2252022-12-08 09:00:24.337 PMinfoDelaying off for 20 minutes
app:2252022-12-08 09:00:24.269 PMinfoMotion inactive: Office sensor
app:2252022-12-08 08:53:09.005 PMinfoSetting dimmers [Office lights] to 40
app:2252022-12-08 08:53:08.998 PMinfoMotion active: Office sensor
app:2252022-12-08 08:52:57.161 PMinfoDelaying off for 20 minutes
app:2252022-12-08 08:52:57.121 PMinfoMotion inactive: Office sensor
app:2252022-12-08 08:48:32.484 PMinfoSetting dimmers [Office lights] to 40
app:2252022-12-08 08:48:32.477 PMinfoMotion active: Office sensor
app:2252022-12-08 08:48:13.041 PMinfoDelaying off for 20 minutes
app:2252022-12-08 08:48:12.980 PMinfoMotion inactive: Office sensor
app:2252022-12-08 08:39:26.779 PMinfoSetting dimmers [Office lights] to 40
app:2252022-12-08 08:39:26.773 PMinfoMotion active: Office sensor
app:2252022-12-08 08:39:25.970 PMinfoDelaying off for 20 minutes
app:2252022-12-08 08:39:25.914 PMinfoMotion inactive: Office sensor
app:2252022-12-08 08:38:20.233 PMinfoSetting dimmers [Office lights] to 40
app:2252022-12-08 08:38:20.227 PMinfoMotion active: Office sensor
app:2252022-12-08 08:37:56.958 PMinfoDelaying off for 20 minutes
app:2252022-12-08 08:37:56.919 PMinfoMotion inactive: Office sensor
app:2252022-12-08 08:18:33.314 PMinfoSetting dimmers [Office lights] to 40
app:2252022-12-08 08:18:33.307 PMinfoMotion active: Office sensor
app:2252022-12-08 07:54:04.579 PMinfoTurning off lights
app:2252022-12-08 07:34:04.556 PMinfoDelaying off for 20 minutes
app:2252022-12-08 07:34:04.516 PMinfoMotion inactive: Office sensor
app:2252022-12-08 07:23:58.106 PMinfoSetting dimmers [Office lights] to 40
app:2252022-12-08 07:23:58.100 PMinfoMotion active: Office sensor
app:2252022-12-08 07:23:18.494 PMinfoDelaying off for 20 minutes
app:2252022-12-08 07:23:18.452 PMinfoMotion inactive: Office sensor
app:2252022-12-08 07:17:34.934 PMinfoSetting dimmers [Office lights] to 40
app:2252022-12-08 07:17:34.928 PMinfoMotion active: Office sensor
app:2252022-12-08 07:17:06.716 PMinfoDelaying off for 20 minutes
app:2252022-12-08 07:17:06.658 PMinfoMotion inactive: Office sensor
app:2252022-12-08 07:15:58.228 PMinfoSetting dimmers [Office lights] to 40
app:2252022-12-08 07:15:58.222 PMinfoMotion active: Office sensor
app:2252022-12-08 07:15:06.120 PMinfoDelaying off for 20 minutes
app:2252022-12-08 07:15:06.064 PMinfoMotion inactive: Office sensor
app:2252022-12-08 07:01:01.207 PMinfoSetting dimmers [Office lights] to 40
app:2252022-12-08 07:01:01.201 PMinfoMotion active: Office sensor
app:2252022-12-08 07:00:00.216 PMinfoSetting dimmers [Office lights] to 40
app:2252022-12-08 07:00:00.195 PMinfoMode change to Evening
app:2252022-12-08 06:59:04.901 PMinfoDelaying off for 120 minutes
app:2252022-12-08 06:59:04.848 PMinfoMotion inactive: Office sensor
app:2252022-12-08 06:37:47.121 PMinfoSetting dimmers [Office lights] to 99
app:2252022-12-08 06:37:47.116 PMinfoMotion active: Office sensor
app:2252022-12-08 06:37:10.280 PMinfoDelaying off for 120 minutes
app:2252022-12-08 06:37:10.237 PMinfoMotion inactive: Office sensor
app:2252022-12-08 06:31:10.892 PMinfoSetting dimmers [Office lights] to 99
app:2252022-12-08 06:31:10.886 PMinfoMotion active: Office sensor
app:2252022-12-08 06:31:00.234 PMinfoDelaying off for 120 minutes
app:2252022-12-08 06:31:00.193 PMinfoMotion inactive: Office sensor
app:2252022-12-08 06:26:16.939 PMinfoSetting dimmers [Office lights] to 99
app:2252022-12-08 06:26:16.934 PMinfoMotion active: Office sensor
app:2252022-12-08 06:22:28.104 PMinfoDelaying off for 120 minutes
app:2252022-12-08 06:22:28.060 PMinfoMotion inactive: Office sensor
app:2252022-12-08 06:21:19.715 PMinfoSetting dimmers [Office lights] to 99
app:2252022-12-08 06:21:19.710 PMinfoMotion active: Office sensor
That is likely the problem with the device, and not with the app. I suggest going into the particular device details by clicking the "info" label, then select the "Events" tab and share a screen shot of that page. Also, would be helpful if you could share the device make and model, as well as the current driver type that is using.
Last but not least, you may want to check this document for other ideas on how to troubleshoot a misbehaving device or app:
