So, I've had a rule which worked great for about 6 months but suddenly is doing weird things.
I have a scene for a single WiZ bulb that is their dynamic sunset mode. This bulb is the only device in the scene. Select function of activate device Off
Turn off all Scene devices is set to Turn off all Scene Devices -
I have a basic rule that activates this scene at sunset. No off time. I turn it off via my dashboard.
Suddenly, it's started functioning properly for 1 minute, then at around one minute turning the light to a different color
Simultaneously with changing the color it turn turns on a light in another room that isn't included in the scene at all
This has happened every day for several days
The only other thing I can think of is that Mode Manager is set to change the mode at Sunset +6 minutes, but this has never affected the scene before and this and if it were the mode change I would expect a 6 minute delay.
The time stamps also seem off, because the dining room light turns on at the same time that the lamp changes color. Slightly after the color change I think, technically.
