Last night I was testing this and it would not even set the right color and kept turning back on even when I told it to turn off. This morning I clicked CONFIGURE and REFRESH on the DEVICE page and now it will set the color but it keeps turning off. I captured the log and this is from me clicking on OFF until all activities stop. I don't get why it will not stay off and when it comes back on it's red and the brightness level has changed...
dev:292020-08-07 05:38:36.039 am infoSlider Light colorMode is RGB
dev:292020-08-07 05:38:36.034 am debugevt- rawValue:0, value: RGB, descT: Slider Light colorMode is RGB
dev:292020-08-07 05:38:36.031 am infoSlider Light color is Red
dev:292020-08-07 05:38:36.015 am debugparse description: read attr - raw: 1F120303000A08003000, dni: 1F12, endpoint: 03, cluster: 0300, size: 0A, attrId: 0008, encoding: 30, command: 01, value: 00
dev:292020-08-07 05:38:35.991 am infoSlider Light colorMode is RGB
dev:292020-08-07 05:38:35.987 am debugevt- rawValue:0, value: RGB, descT: Slider Light colorMode is RGB
dev:292020-08-07 05:38:35.984 am infoSlider Light color is Red
dev:292020-08-07 05:38:35.957 am debugparse description: read attr - raw: 1F120303000A08003000, dni: 1F12, endpoint: 03, cluster: 0300, size: 0A, attrId: 0008, encoding: 30, command: 01, value: 00
dev:292020-08-07 05:38:35.867 am infoSlider Light colorMode is RGB
dev:292020-08-07 05:38:35.864 am debugevt- rawValue:0, value: RGB, descT: Slider Light colorMode is RGB
dev:292020-08-07 05:38:35.861 am infoSlider Light color is Red
dev:292020-08-07 05:38:35.849 am debugparse description: read attr - raw: 1F120303000A08003000, dni: 1F12, endpoint: 03, cluster: 0300, size: 0A, attrId: 0008, encoding: 30, command: 01, value: 00
dev:292020-08-07 05:38:35.690 am infoSlider Light is 100%
dev:292020-08-07 05:38:35.687 am debugevt- rawValue:255, value: 100, descT: Slider Light is 100%
dev:292020-08-07 05:38:35.678 am debugparse description: read attr - raw: 1F120300080A000020FF, dni: 1F12, endpoint: 03, cluster: 0008, size: 0A, attrId: 0000, encoding: 20, command: 01, value: FF
dev:292020-08-07 05:38:35.650 am infoSlider Light is 100%
dev:292020-08-07 05:38:35.645 am debugevt- rawValue:255, value: 100, descT: Slider Light is 100%
dev:292020-08-07 05:38:35.631 am debugparse description: read attr - raw: 1F120300080A000020FF, dni: 1F12, endpoint: 03, cluster: 0008, size: 0A, attrId: 0000, encoding: 20, command: 01, value: FF
dev:292020-08-07 05:38:35.536 am infoSlider Light was set to 100%
dev:292020-08-07 05:38:35.533 am debugevt- rawValue:255, value: 100, descT: Slider Light was set to 100%
dev:292020-08-07 05:38:35.525 am debugparse description: read attr - raw: 1F120300080A000020FF, dni: 1F12, endpoint: 03, cluster: 0008, size: 0A, attrId: 0000, encoding: 20, command: 01, value: FF
dev:292020-08-07 05:38:35.459 am infoSlider Light saturation is 100%
dev:292020-08-07 05:38:35.453 am debugevt- rawValue:254, value: 100, descT: Slider Light saturation is 100%
dev:292020-08-07 05:38:35.442 am debugparse description: read attr - raw: 1F120303000A010020FE, dni: 1F12, endpoint: 03, cluster: 0300, size: 0A, attrId: 0001, encoding: 20, command: 01, value: FE
dev:292020-08-07 05:38:35.401 am infoSlider Light saturation is 100%
dev:292020-08-07 05:38:35.397 am debugevt- rawValue:254, value: 100, descT: Slider Light saturation is 100%
dev:292020-08-07 05:38:35.391 am debugparse description: read attr - raw: 1F120303000A010020FE, dni: 1F12, endpoint: 03, cluster: 0300, size: 0A, attrId: 0001, encoding: 20, command: 01, value: FE
dev:292020-08-07 05:38:35.345 am infoSlider Light saturation was set to 100%
dev:292020-08-07 05:38:35.341 am debugevt- rawValue:254, value: 100, descT: Slider Light saturation was set to 100%
dev:292020-08-07 05:38:35.329 am debugparse description: read attr - raw: 1F120303000A010020FE, dni: 1F12, endpoint: 03, cluster: 0300, size: 0A, attrId: 0001, encoding: 20, command: 01, value: FE
dev:292020-08-07 05:38:35.267 am infoSlider Light hue is 100%
dev:292020-08-07 05:38:35.264 am debugevt- rawValue:254, value: 100, descT: Slider Light hue is 100%
dev:292020-08-07 05:38:35.251 am debugparse description: read attr - raw: 1F120303000A000020FE, dni: 1F12, endpoint: 03, cluster: 0300, size: 0A, attrId: 0000, encoding: 20, command: 01, value: FE
dev:292020-08-07 05:38:35.211 am infoSlider Light hue was set to 100%
dev:292020-08-07 05:38:35.208 am debugevt- rawValue:254, value: 100, descT: Slider Light hue was set to 100%
dev:292020-08-07 05:38:35.191 am debugparse description: read attr - raw: 1F120303000A000020FE, dni: 1F12, endpoint: 03, cluster: 0300, size: 0A, attrId: 0000, encoding: 20, command: 01, value: FE
dev:292020-08-07 05:38:35.174 am infoSlider Light hue was set to 100%
dev:292020-08-07 05:38:35.170 am debugevt- rawValue:254, value: 100, descT: Slider Light hue was set to 100%
dev:292020-08-07 05:38:35.157 am debugparse description: read attr - raw: 1F120303000A000020FE, dni: 1F12, endpoint: 03, cluster: 0300, size: 0A, attrId: 0000, encoding: 20, command: 01, value: FE
dev:292020-08-07 05:38:34.418 am infoSlider Light is on
dev:292020-08-07 05:38:34.413 am debugevt- rawValue:1, value: on, descT: Slider Light is on
dev:292020-08-07 05:38:34.388 am debugparse description: read attr - raw: 1F120300060A00001001, dni: 1F12, endpoint: 03, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 01
dev:292020-08-07 05:38:34.349 am debugparse description: catchall: 0104 0008 03 01 0040 00 1F12 00 00 0000 0B 01 0400
dev:292020-08-07 05:38:34.250 am debugparse description: catchall: 0104 0008 03 01 0040 00 1F12 00 00 0000 0B 01 0400
dev:292020-08-07 05:38:34.243 am debugparse description: catchall: 0104 0008 03 01 0040 00 1F12 00 00 0000 0B 01 0400
dev:292020-08-07 05:38:33.093 am debugparse description: catchall: 0104 0300 03 01 0040 00 1F12 00 00 0000 0B 01 0600
dev:292020-08-07 05:38:33.045 am debugparse description: catchall: 0104 0300 03 01 0040 00 1F12 00 00 0000 0B 01 0600
dev:292020-08-07 05:38:32.992 am debugparse description: catchall: 0104 0300 03 01 0040 00 1F12 00 00 0000 0B 01 0600
dev:292020-08-07 05:38:32.938 am debugparse description: catchall: 0104 0006 03 01 0040 00 1F12 00 00 0000 0B 01 0000
dev:292020-08-07 05:38:32.532 am infoSlider Light was turned on
dev:292020-08-07 05:38:32.528 am debugevt- rawValue:1, value: on, descT: Slider Light was turned on
dev:292020-08-07 05:38:32.518 am debugparse description: read attr - raw: 1F120300060A00001001, dni: 1F12, endpoint: 03, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 01
dev:292020-08-07 05:38:31.481 am debugparse description: catchall: 0104 0006 03 01 0040 00 1F12 00 00 0000 0B 01 0100
dev:292020-08-07 05:38:31.190 am infoSlider Light was turned off
dev:292020-08-07 05:38:31.164 am debugevt- rawValue:0, value: off, descT: Slider Light was turned off
dev:292020-08-07 05:38:31.155 am debugparse description: read attr - raw: 1F120300060A00001000, dni: 1F12, endpoint: 03, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
dev:292020-08-07 05:38:30.231 am debugparse description: catchall: 0104 0006 03 01 0040 00 1F12 00 00 0000 0B 01 0000
