I have 4 Inovelli Scene switches. I have been using them in rule machine for a few things.
For example:
When I double tap down on the Master Bedroom switch, it turns off the Master Bedroom lights, turns on the fans attached to the smart plugs, and turns the thermostat to 70 degrees.
When I triple tap down on the Master Bedroom switch, it does the same as double tap, but it turns off all the house lights.
These are currently 2 rules I have set up in Rule Machine. I just noticed that I can use the switch as a Button Device and assign the same scenarios above under just 1 rule instead of 2.
My question is... Is it more beneficial/smarter/efficient to use the switch as a button device in rule machine, or keep it as a button and have more rules?
