Try this
* LIFX Scene
* Copyright 2016 Eric Vitale
* Version 1.0.3 - Fix to support the new SmartThings app. (08/20/2018)
* Version 1.0.2 - Added the switch capability in order to use this device with Alexa (10/3/2017)
* Version 1.0.1 - Converted to Async API (06/21/2017)
* Version 1.0.0 - Initial Release (05/31/2017)
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "LIFX Scene", namespace: "ericvitale", author: "ericvitale@gmail.com", vid: "generic-button") {
capability "Actuator"
//capability "Button"
capability "Momentary"
capability "Sensor"
capability "Switch"
command "activateScene"
preferences {
section("LIFX Configuration") {
input "token", "text", title: "API Token", required: true
input "scene", "text", title: "Scene UUID", required: true
input "defaultTransition", "decimal", title: "Default Transition Time", required: true, defaultValue: 1.0
section("Settings") {
input "logging", "enum", title: "Log Level", required: false, defaultValue: "INFO", options: ["TRACE", "DEBUG", "INFO", "WARN", "ERROR"]
private determineLogLevel(data) {
switch (data?.toUpperCase()) {
case "TRACE":
return 0
break
case "DEBUG":
return 1
break
case "INFO":
return 2
break
case "WARN":
return 3
break
case "ERROR":
return 4
break
default:
return 1
def log(data, type) {
data = "LIFX -- ${device.label} -- ${data ?: ''}"
if (determineLogLevel(type) >= determineLogLevel(settings?.logging ?: "INFO")) {
switch (type?.toUpperCase()) {
case "TRACE":
log.trace "${data}"
break
case "DEBUG":
log.debug "${data}"
break
case "INFO":
log.info "${data}"
break
case "WARN":
log.warn "${data}"
break
case "ERROR":
log.error "${data}"
break
default:
log.error "LIFX -- ${device.label} -- Invalid Log Setting of ${type}."
log.error "Message = ${data}."
def push() {
activateScene(scene, defaultTransition)
sendEvent(name: "button", value: "pushed", isStateChange: true)
def on() {
push()
def off() {
log("Method off() not implemented, this is ok.", "INFO")
def activateScene(uuid, duration=defaultTransition) {
//commandLIFX(uuid, "PUT", "duration=${duration}")
def command = ["duration": duration]
commandLIFX(uuid, "PUT", command)
//////////// BEGIN LIFX COMMANDS ///////////
def commandLIFX(light, method, commands) {
def rawURL = "https://api.lifx.com"
def rawPath = ""
rawPath = "/v1/scenes/scene_id:" + light + "/activate"
def rawHeaders = ["Content-Type": "application/x-www-form-urlencoded", "Authorization": "Bearer ${token}"]
def params = [
uri: rawURL,
path: rawPath,
requestContentType: "application/json",
headers: rawHeaders,
body: commands
log("Full URL/Path = ${rawPath}.", "DEBUG")
log("rawHeaders = ${rawHeaders}.", "DEBUG")
log("body = ${commands}.", "DEBUG")
log.debug params
asynchttpPut('responseHandler', params)
def responseHandler(response, data) {
if(response.getStatus() == 200 || response.getStatus() == 207) {
log("Scene Activated.", "DEBUG")
} else {
log("Scene failed to activate. LIFX returned ${response.getStatus()}.", "ERROR")
////////////// END LIFX COMMANDS /////////////
